0 Members and 116 Guests are viewing this topic.
cosmoLV
Quote from: forest on February 14, 2012, 04:10:10 PM
cosmolv
answer :
1. is there any coil inside ferrite tube (made from rings) in delamorto device or all windings are on ferrite
2. is delamorto device producing harmful radiation or radio hash
1.) No there are only cooper pipe with a notch â€" see Delamorto video where it shows that, i show it in one of my video something about 2 years ago.
2.) yes and No (depending on frequency and ferrite rings) if frequency is to high you can get headaches
Keep your chakras opened :)
cosmoLV
Quote from: dllabarre on February 14, 2012, 04:12:51 PM
Last year (2011):
I asked you questions in PM regarding the device and you didn't answer me.
I asked you questions in forum regarding the device and you didn't answer me.
So don't say you answer question regarding the device.
You only answer the questions you want to.
You created enough Karma between u and me already. I'm not getting into the deals on that.  you know what I'm talking about.
No More!!
I'm done discussing this with u so don't bother quoting and/or responding to this.
DonL
Maybe i miss something or not have time and forget.
but if you have carma, no problem, this is your business. I personally don't have any bad thoughts to noone...
rensseak
Quote from: cosmoLV on February 14, 2012, 03:55:20 PM
"You know more than US government who took most Tesla secrets." (who take Tesla secrets?) Government? You kidding me? :D
i have Tesla notes and patents directly from FIB â€" there are no secrets. Only secret is that these files are hidden from public long time, but now these files are everywhere!
Can you be sure to have all of them? So why you do not share it with us?
duff
Quote from: ronotte on February 14, 2012, 12:43:39 PM
Hi Stefan, watssup,
waiting for the fire dying on this thread, as suggested I did some test in order to see if any weird in pulsing an Iron coil in comparison with a Cu coil.  I did the test using as 'generator' the Caduceus pickup coil device as on the output there are (after SG2) 200nsec 1KV positive spikes with 150 nsec mid duration and 1Khz repetition rate.
First: I have wound a flat bifilar Fe/Cu using 10mt   10mt wires and 1mm diam (full inductance, resistance and inter capacitance, ecc recorded). Coil wounded onto a 5 cm carton tube,  then I pulsed alternatively the Fe side only and the Cu side only. While pulsing one side I looked at the other side. Results: NONE, the behaviour is the same just as expected.
Second: I connected the two windings as serial bifilar cancelling and I pulsed the top extremities while looking if any weird happening by means of another coil wound over. Results: NONE.
Sorry for that...but it is just what I expected because the energy imparted only 1.5Kev. Any Fe decay is expected for at least 8Mev.
Roberto
Roberto,
How did you come up with  1.5Kev for your system?
Would you please explain the calculations?
Thanks
core
Regarding the ground, I recall a translation were Tariel stated the the unit must have a ground but this didn't have to be an 'earth' ground. This ground could be a large object such as the frame of a car or truck.
Another interesting thing that Tariel stated about the ground wire was that in one experiment his assistant disconnected the ground while the unit was running. This caused the unit to overheat/fry/over load (paraphrasing).
-Core
