0 Members and 118 Guests are viewing this topic.
duff
Quote from: ronotte on February 15, 2012, 03:36:42 AM
Hi duff,
in phisics 'elettronvolt' (eV) is an energy measure unit and is defined as the kinetic energy received by one free electron when accelerated by a 1V ddp (in the vacuum). Kev is just the energy imparted to electrons when subjected to 1KV ddp. In my case there is a little error because my device is not in the vacuum but it is anyway subjected to a 1KV ddp range voltage pulse. Big Linear or toroidal accelerators are generally able to reach Mev (Million elettron volt) or Tev (Tera elettron volt) energy for example to an electron beam accelerating it till near c speed. The conversion to Joule is:
1 eV = 1,602 176 53 × 10âˆ'19 J
In particles phisics, Mev and Jev are often utilized to measure elementary particles mass by means of Einstein restrict relativity:E = m cwhere E is energy, m is mass and c è la light speed in vacuum. Electron mass is equivalent to 0,511 MeV/c2.
Roberto
Roberto,
Sorry, maybe I didn't  state the question clearly.
I just  wanted to see your math.
Thanks
frantz
OK,
fiends, in this picture:
http://freeenergylt.narod2.ru/kapanadze_6/kapanadze3.jpg
you can see two HV diodes in right upper corner. In my opinion is not wires.
Next thing is two white wires.
One is going in to tube from ground connection,
Second going out from tube in other side to can cover.
in my opinion can be ends of hidden coil or copper tube under the main orange coil.
Next thing are words which TK said.
Melnichenko gave him background.
How is working Melnichenko device?
this is a HF transformer 1:1 which have pulse generator on input and powering input coil by positive pulses.
On the output is inserted diode which blocking normal pulse and forwarding to load only BEMF. In this point magnetic coupling not exist from input point of view and output is powered by BEMF only.
One thing is not clear for me:
Melnichenko used ferrite, TK in 2004 not....
forest
I don't know whay is ferrite bad and can work only up to 600W as stated by cosmolv ???
It has to be related to other elements inside ferrite , not iron, but why ? Isn't ferrite supposed to work in power inverters ??? Especially those from monitors yoke , shuld work without troubles. What experts can say about it ?
The rest is easy : follow Melnichenko. Nature will copy the energy as opposite dipole if we can create our own one without shorting it.
Let's say we need 3000W. That's 3000 Joules/s continuous. Using 230V/50Hz it means 100 impulses (50 in one direction and 50 in opposite) per second. One impulse is carrying 3000/100=30 Joules
Now please compute how easily we can make it work with 4700uF capacitor at 1Khz DC pulses. IF we know how to make capacitor continuously charged of course. What voltage on this capacitor is needed ?
Then switch to this topic: [size=78%]http://www.overunity.com/11961/ghazanfar-ali-generator-utlilizing-trapped-energy/new/topicseen/#new[/size][size=78%] [/size]
CosmoLV please ANSWER WHY ONLY 600W from ferrite ?!
scratchrobot
Quote from: frantz on February 15, 2012, 11:06:21 AM
Hi Cosmo
you don't answer for simple question:
What for, for you, is this forum.
For the rest people is for learning and shering knowledge....
But for you... ???
Cosmo only answers questions about device?
frantz
Hi forest,
for the topic, in my point of view TK used combination of two phenomena.
1. Melnichenko effect (BEMF) for generating FE,
2. smart transformer (without induction - negligible small) for transforming to the output - link to the Russian movie:
http://www.youtube.com/watch?feature=player_embedded&v=cL8fAa5My-Q
rest is a piece of cake... ;-) joke.
