0 Members and 41 Guests are viewing this topic.
a.king21
T 1000
  It looks like a classic tetrode beam  valve/tube setup: If so it is an (RF) radio transmitter setup. Therefore  you are burning your coils with radio transmission, and possibly youself. It could be dangerous. It is not Tesla cold electricity.
  Beam Tetrode http://en.wikipedia.org/wiki/Tetrode
   A pentode is  http://en.wikipedia.org/wiki/Pentode
Jury1
I saw FreeEnergyInfo experiments, and remembered how in youth, gathered transmitter at the tetrode the 6P3S
http://www.radiotehnica.ru/kompl/lamp/6_lamp/6p3s.jpg
Here is this circuit  http://6p3s.ru/pics/classical-1.GIF
This scheme did not work stably. Why? In this lamp arose "dynatron effect."
I was afraid that the lamp goes down, and turned off the power from the mains.
The transmitter has continued to work! I had to pull out the bulb from the socket, to stop the work of the transmitter.
ronotte
Hi Stefan,
the pic: http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/dlattach/attach/95822/, does show clearly that there is a connection to the oscillator grid labelled 'modulation'. Clearly the 50Hz reference freq is inputted there. The funny is the use of 'shield grid' as a way of modulation input as in such a case certainly you need more voltage.
On the other end the other picture shows a self runner where the transformer output is connected to shield grid'...if standard iron-core XFORMER used it does allow passing of only low frequency, but there I do not see like you any low freq source. The circuit itself http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/dlattach/attach/95834/ I think is to be considered partial as it cannot start in that way because the tube's filament initially is not powered. Some initial condition must be considered :)
I'm quite sure that this comes from Stivep... I think I could use as exciter my YAESU transceiver FT-277E as 80 meters band (3.5MHz) exciter just driving a 50 ohm impedance coil in the stivep coil-set... (Stivep, if you happen to come in Italy pse QSY to my home, 73 from I0LY).
Roberto
core
  Going back to the motor video on the home page I find it odd that the entire assembly is raised off the ground with rubber tires. Figure that the frame is welded from 5" or so 'I' beams and the bearing mounts and bottom plate from 1/4" steel. All together just the frame weighs in at about 200 - 300 pounds.
  Adding a large generator with what appears to be a 10-15HP motor will then add an additional 300 - 400 pounds. In all, on the low end it weighs in at 500Lb, on the high end 700LB. This is a bit scary to have balanced on some rubber tires. The argument that the tires are there to show that there are no wires from beneath is invalid. This, of course, do to that fact that the tires themselves block any view from underneath.
  From the home page video you don't see anyone go near the frame(I don't know if there is an extended video). I would argue that the entire frame + generator is energized electrically and forms one pole (oscillating) of an electric field. Perhaps the air forms the other( top capacitance typically found on a Tesla coil).
  In the video they focus on a hole drilled into the steel. Is this the location of the spark gap? I would venture a guess that the spark gap is hitting the wave(electric) right at the ebb and flows of the wave. Regardless most/if not all people, dont even build one OU device. It is unbelievable that Tariel has many different flavors.
-Core
T-1000
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/dlattach/attach/95834/ has step up transformer missing to Pentod's Anode
The measurments:
1) On Anode it is 315 V pulsed DC, approx 50mA.
2) The Tr2 and Tr1 are 50Hz 10W transformers, taking 50Hz from the grid. The purpose of them is 50Hz signal source, not power.
3) The Pentod Anode is connected to step up transformer. That transformer connects to parallel of Tr2 and 50Hz phase must match.
4) It was not possible to take precise Amp reading on Tr2, so lets say, it is 10W as maximum per transformer
5) Pendode heating element takes more than 15 Watts when heating and 12W when in working condition.
6) The 100W halogen is attached as load.
7) The secondary of Tesla coil is split into two parts: 1st is 1/4 of second coil length. The distance between them on tube is 3.5 cm.
Also, this circuit uses general idea of RF equipment but does not operate in conventional way. There is ionization on Tesla coil going on and there are coil-capacitors inside of Tesla Coil. The Tesla Coil is tunned to 800kHz resonant frequency.
So here is question: is it possible to light and overheat 100W halogen with 16W power input..?
The answer most likely will be shown when you repeat this circuit... :)
P.S.> The longer secondary coil part is winded into opposite direction in regards to first 1/4 length coil. The receiving Tesla coil (inside of transmitting coil) is winded opposite to transmitting Tesla coil.  Also you can have receiving Tesla coil outside of transmitting Tesla coil.
