0 Members and 180 Guests are viewing this topic.
firlight
Quote from: T-1000 on February 23, 2012, 12:05:43 PM
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/dlattach/attach/95834/ has step up transformer missing to Pentod's Anode
The measurments:
1) On Anode it is 315 V pulsed DC, approx 50mA.
2) The Tr2 and Tr1 are 50Hz 10W transformers, taking 50Hz from the grid. The purpose of them is 50Hz signal source, not power.
3) The Pentod Anode is connected to step up transformer. That transformer connects to parallel of Tr2 and 50Hz phase must match.
4) It was not possible to take precise Amp reading on Tr2, so lets say, it is 10W as maximum per transformer
5) Pendode heating element takes more than 15 Watts when heating and 12W when in working condition.
6) The 100W halogen is attached as load.
7) The secondary of Tesla coil is split into two parts: 1st is 1/4 of second coil length. The distance between them on tube is 3.5 cm.
Also, this circuit uses general idea of RF equipment but does not operate in conventional way. There is ionization on Tesla coil going on and there are coil-capacitors inside of Tesla Coil. The Tesla Coil is tunned to 800kHz resonant frequency.
So here is question: is it possible to light and overheat 100W halogen with 16W power input..?
The answer most likely will be shown when you repeat this circuit... :)
P.S.> The longer secondary coil part is winded into opposite direction in regards to first 1/4 length coil. The receiving Tesla coil (inside of transmitting coil) is winded opposite to transmitting Tesla coil.  Also you can have receiving Tesla coil outside of transmitting Tesla coil.
Come on now ,Its a Beam Tetrode not a Pentode There is a difference .
Dave :)
stivep
Quote from: firlight on February 23, 2012, 12:24:16 PM
Dave :)
It is like you say
you Jonhn Smith .or I'm sorry
you John  Smith.........
What different does it make?
You dealing with the same person  and you talking to the same person..
Got the message?
SIR? ??? ??? ?
You response should be..
"I understand concept there  is just wording to be corrected"
BUT even  at that point you may be in error SIR look at last link of this post...
Did you make statement of understanding or you pointing to the skirt  of  Gentleman girlfriend while steering at her legs...
instead  you should be  concentrating yourself on Gentleman  brain.
http://www.magictubes.ru/sprav/pdf/6p36s.pdf
Wesley
PS:
It is you who is analyzing Arunas  explanation
and
It is not Arunas  analyzing your consent about.
I make many mistakes as I was not born American nor is Aidas or Arunas.How many languages do you speak  Sir I went across of understanding more than 5 and being fluent in and least 3
Typical American
"Back in 1940, less than 5 percent of Americans 25 and older had bachelor's degrees. Now, according to data released by the Census Bureau in December, nearly
28 percent do"
http://chronicle.com/article/Census-Data-Reveal-Rise-in/126026/
Typical Russian
"According to a 2005 UNESCO report, 96% of the adult population has completed lower secondary schooling and most of them also have an upper secondary education."
That means
most of them have bachelor degree
http://en.wikipedia.org/wiki/Education_in_Russia
96/2=48 percent "do"
Sir...
dear sir cow will be cow even with three legs
look at this link it says pentode
http://www.elektrohobby.de/Bauelemente/Verstaerker-Roehre/6P36C-6GB5-EL500-Pentode.html
So who is right  and who is  wrong? ??? ??? ??? ??? ??? ?
andrea76
about the video of motor at min 20:57 the toroidal transformer probably induced the high frequency pulsed DC current from metallic box to the shaft.in the video 01 that transformer is different (the three primary coils here we are,in the video 02 there are only two black wire that feed the toroid). I think the step are: TK built the electrolizer for the engine,during his experiment discover the phenomenon of magnetic collection and apply this on the rotor for drive the alternator. after built a solid stated device.from min 16:20 to 18:14 the rotor is unloaded.look how fast turns.... (high frequency current, Thomas Moray had a motor running 360000 t/min).When the beat of the two frequency running into the toroidal coil interact with the environment (earth magnetic field) http://www.youtube.com/watch?v=qVUN3GsekKQ&feature=relmfu
Kator01
The measurments:
Hello T-1000,
for an in-depth understanding of the dynatron-effect: here is a german website which explains the suppressor-grid-action ( do not be scared though..it is all written in english) and a possible dynatron converter ( dynatron-mode is an oscillation-mode ):
http://www.radiomuseum.org/forum/1619_1619_suppressor_action.html
http://www.radiomuseum.org/forum/df97_pentode_and_tetrode_curves.html
http://www.radiomuseum.org/forum/a_very_simple_one_tube_transmitter.html
Quote : "This behaviour will result in a negative resistance, cancelling out the damping of the L-C circuitry"
Kator01
firlight
Quote from: stivep on February 23, 2012, 12:39:24 PM
It is like you say
Got the message?
SIR? ??? ??? ?
instead of concentrating on Gentleman  brain.
Wesley
PS:
and
Typical American
28 percent do"
Typical Russian
That means
96/2=48%
Sir...
I am trying to keep it real there will be people who have no experience with valves,
  wording is very important as it can create confusion you need to dot the i `s and cross
t`s if you are going to publish information ,it also does not look good for the publisher of that information.
Dave :)
