dllabarre
Quote from: T-1000 on February 24, 2012, 12:37:54 PM
The our experiment clearly shows power coming from Tesla Coil and this effect from mixing with another frequency.
So you can have lets say, 50Hz with 800kHz inside -
http://freeenergylt.narod2.ru/aidas/2_pirmine_iskociojimas_pjuklas__50_hercu.jpg
Is that OU (tapping for external energy to ambient background)? Time will show... :)
Makes sense to me.  I understand.
Thank you
DonL
dllabarre
Quote from: FreeEnergyInfo on February 24, 2012, 04:50:19 PM
FREE DOWLOAD  .....
KAPANADZE  DVD  DISK ....
RAR ...
www.narod.ru/disk/41805204001/Tariel_Kapanadze.part1.rar.html
www.narod.ru/disk/41816767001/Tariel_Kapanadze.part2.rar.html
www.narod.ru/disk/41807708001/Tariel_Kapanadze.part3.rar.html
I couldn't down load the rar files.
I went to the URL link, entered the number code, clicked download and it just went to another web page and didn't start a download.
I couldn't find anything on the second web page to click to start the download.
Can you put the rar files on ur server so we can get a direct download from your website?
Thank you
DonL
FreeEnergyInfo
Quote from: dllabarre on February 24, 2012, 07:06:23 PM
Thank you
DonL
PLYZ VIEV .....
bolt
Quote from: dllabarre on February 24, 2012, 11:11:44 AM
I used a Kapagen in a similar fashion to light 18 x 100 watt light bulbs with HV HF using 178Watts input.
I've always wondered if Kapanadze Green Box is doing a similar thing.
Is he really lighting the bulbs with 50hz 220V or HV HF??
Don
I wouldn't compare kapagen to ANYTHING as anyone that  have tried to validate the TRUE power readings were very disappointed.   Kapagen is ancient history on here now as a defunct project once it was established energy power meters and amp clamp meters designed for 50-60hz give the most crazy unrealistic  readings when confronted by 1000 watts of sparking HASH!  If you really want to measure kapagen then measure it via a 12v truck battery and 2000w inverter and measure the DC volts and DC battery amps.
Tesla proved that incandasent lamps lit brighter with less power using HF HV. This is because the gas or depleted air ionises much better at HF.  Of course this is not the entire picture as REAL power can be taken from kapanadze and TPU devices.   There are many devices even joule thief's that can provide up to COP 10 in the milliwatt range but when you get COP >100 as kapanadze or COP 1000 as the TPU or Sweet VTA clearly something VERY special is going on to provide such a large source to load isolation.  It appears to me kapanadze may have used TWO isolation stages so a COP of 10 *10 = 100.   Or i can reverse engineer this as 5kw o/p is about a 50 watt driver and the TPU and VTA are operating in 3 dimensions XY and Z planes or
TPU 1 watt driver 103 =10 x 10 x 10= 1 000 watts
[/color][/font][/size]BUT so far i have seen conversion from VARS to WATTS in RV's is only about 10% in so to get 5kw o/p requires a 50 watt driver about 50  kVARS in reactive power going around those coils.
Like any powerful  amplifier to get overall system POWER gain requires multiple stages EXCEPT of positive feedback we require negative feedback where each stage is a negative resistor or source to load isolator!
