AbbaRue
What convinces me of OU isn't the light bulbs he is lighting.
It's the arc he draws when he brings the leads together.
The arc doesn't change the draw off the battery,
and that arc is much more then 6 watts would give you.
Input:  12v x 500mA = 6 Watts.
As for the spacer rods:
I was wondering if there is anything out there already evenly grooved.
Cutting grooves along a rod and getting them exact sounds like a nightmare.
Maybe some kind of plastic comb that has the same size teeth all the way down it.
Must be something we can use.  $120 a coil is a lot of money.
joefr
Hi AbbaRue
For making your own air coil look at the pdf document I attached
JoeFR
stivep
Quote from: T-1000 on March 05, 2012, 11:57:53 AM
You are on the right track! Resonance, then minimum input power with maximum output!
And when dialectric starts to burn, you are actually making it as live wire. Now http://www.youtube.com/watch?v=x9pAmgCwwFA will make sense to you :)
The draw of energy from ambient source is already in flyback!
Also our team discovered about Russian "smart" flyback, it had double secondary instead of single secondary:
1) First secondary is winded clockwise;
2) The good dielectric laid on top;
3) 4 times longer secondary is winded counetr clockwise
So in general it is basic Tesla 1/4 wave resonator with receiving coil inside.. :)
Please View new video that is explaining mechanics of FE in TK devices.
http://www.youtube.com/watch?v=HKVyeQkW8j0&feature=youtu.be
NYW Group presents:
Video#1 :
Sine wave 3D. Energy dependency from  sustaining factors.
Spark Gap particle acceleration.
Plasma acting like coil.
Property of Cosmic Ray assumed as similar to Photon in nature.
Switching sequence to get the effects of desired operation.
There are two parts in  this video.
Second part starts from 15:18 minute of video.
How many times have you been  analyzing electrostatics, electromagnetics, in spacial form?
video#1  IS FIRST OF SERIES ....
"GET THEM BY THE BALLS ........."
Wesley
27Bubba
@joefr
Thanks for the link to the pdf file I was looking for something like that.
andrea76
Quote from: andrea76 on March 10, 2012, 05:38:09 AM
see this video with translationhttp://www.youtube.com/watch?v=Goq76CQapyI
at min 12:59 the guy takes the shock: the transistor operated at 220 volt not 12 or so.the wrong reading of the voltmeter is not due to the magnetic field but in the high frequency component of the output current.again : can the tesla longitudinal wave are related to the gravity?? that wave travel to the straight black wire (grounding cable).this cable had wrapped  around the  blue coil (220 turns for 220 volt output) ???  mmm....
