cheappower2012
I have been watching this TK saga for a while,it reminds me of the tpu saga.
The inventor of the tpu didn't want hes invention,to be used by the masses
unless he made a bunch of money.He create a myth that he can't lie ,wouldn't lie and
wants you to build hes tpu to power your house.I Have extensively studied the tpu and the inventor,I see TK
as similar to the tpu inventor that is they want money,and don't care about mankind,there deceptive,tricky.
In SM's (tpu inventor)case he worked alone,in TK case he has minions  aka helpers,wooshman for one,from the green box video,
a lot of people know how to build the device,all want money,so even if TK wanted to release
the information(which I don't think he does),the minions would not want the information public.
I believe that the build in turkey has some problems with it so didn't go any where,its either
fake or has problems that can only be solved by someone knowing exactly how it works which no one knows how it works.
I find it strange that everybody is building replications that do not look anything like the original device(green box video) and expect it to work.
It seems bigger spark more chance of it working does not fit whats on the video's,small spark.
My opinion is TK if he recovers,(its a good bet that someone close to him let him have it),he will seek to sell it to someone for big money
or if TK doesn't recover the minions will try to sell it to someone for big money,since they know how to build it.
There are many clues in the green box video and 2004 video,I think any information from either TK or hes minions will be misinformation as any thing from SM(inventor of the tpu) is misinformation.
stivep
Quote from: forest on May 06, 2012, 02:35:09 PM
C-niko are capacitors ? Electrolytic ?  :o
ignitors look at ebay link in my post above
or...
mercury-vapor lamp
http://en.wikipedia.org/wiki/Mercury-vapour_lamp
http://www.ebay.com/itm/Philips-SAH-250-
B-Short-Arc-Mercury-Vapor-Lamp-Availability-
Problems-/180833668071?pt=LH_
DefaultDomain_0&hash
=item2a1a86cbe7#ht_784wt_962
breake the glass take interior tube out put it into oil
I think presentation of TK  Bed ( in the house) that what was in the can inside,
Put two electrodes  in form of flat copper  or aluminium sheet from each side of the glass envelope  of that inner tube taken out of street sodium or mercury vapor bigger envelope of lamp.
connect  light bulb to it
Mineral oil serves as cooling medium.
than we have had:
- 2 spark GAPS  ONE  EXPOSED  ONE IN THE METAL CAN.+ electric motor used as frequency generator with no load connected to the shaft. used as fan for cooling something that not need to be cooled.The motor is 220V motor not 12V!!!
SIMILARITY:
- glass table presentation Turkey:  ( two hidden spark Gap)(equivalent of 2 spark gaps) for each of phase.+ electric motor used as frequency generator with no load connected to the shaft.
Probability of right assumption:
90%
-Tent Presentation Turkey: stack of ignitors (equivalent of 2 spark gaps) for each of phase. [/size]+ electric motor used as frequency generator with no load connected to the shaft.
90%
- Tbilisi presentation for me: one ignitor for gas  water heater with two HV output from transformer connected to  one coax cable coil (equivalent of 2 spark gaps)
90%
-green box one exposed spark gap possibly second one inside + electric motor used as frequency generator with no load connected to the shaft. used as fan for cooling something that not need to be cooled.The motor is 220V motor not 12V!!!
90%
- German and Tbilisi presentation of disc motor. one of motors is used as frequency generator..so where is spark gap?
Electronic board might be  used  similar way as igniton from show made for me.. or as typical to this  kind of motors contact point to the disk using bearing as cover-up.
Not established as of yet.
-Please analyze also  Turkey in the house presentation Fan is present as well. I do not remember what about spark.
- Please analyze Aquarium  Presentation as well.
http://cgi.ebay.com/ws/eBayISAPI.dll?
ViewItem&_trksid=p4340.l2557&item=
180835174323&nma=true&rt=nc&si=
hasbijBl48ZJbq7DHAHPSrNzG1s
%253D&sspagename=STRK%
3AMEWAX%3AIT&orig_cvip=
true&rt=nc#ht_1278wt_1140
Standard version or with automatic switch-off Compact shape For high pressure sodium lamps (HS),metal halide lamps (HI) andceramic discharge lamps (C-HI)Ignition voltage: 4â€"5 kVPhasing of the ignition voltage:60â€"90 °el and 240â€"270 °elMax. permitted casing temperature: 105 °CFastening: male nipple with pre-assembledwasher and nutFor luminaires of protection class I and IIFor luminaires of protection class I(140594, 147707)[/color]Wattage: 70-400W
Voltage AC 50-60Hz: 220-240V
Max. lamp current: 5A
internal loss: <3W
Ignition Voltage: 4-5kV
Lentgh: 80mm
Width: 34mm
High: 30mm
Weight: 150g
NOTICE:
word "Plasma" might not be the most accurate as we dealing with strong ionization visible to  human eye,
At that point plasma might be non direct emission due to  dielectric constant of dielectric not being able to withhold ion flow.
We assume that this is what TK has noticed when he was experimenting with  not so good quality of insulating materials and this is what he  utilized as positive side effect.
At least one of ignitors spark gaps is made in ion plasma enclosed environment
-Caduceus from Aidas and my experiment
Plasma between non good quality dielectric between caduceus and pickup coil.
- show for me in Tbilisi presence of plasma inside coax cable based on two ends of HV transformer of ignitor connected  one end  shield  second to inner wire of coax.(equivalent of 2 spark gaps)
Please analyze 3 point connection of presentation made to me as the third one in the middle of coax was only for sensing electrode of the ignitor.
recent additions:
250-B-Short-Arc-Mercury-Vapor-Lamp-
Availability-Problems-/180833668071?pt=LH_DefaultDomain_0&hash=item2a1a86cbe7#ht_784wt_962
Wesley
Pictures:
1 TENT PRESENTATION TURKEY BANK OF IGNITORS
2 GLASS TABLE PRESENTATION ( read related  text)
3 KAPAGEN SCHEMATIC ( motor to be analyzed as pull- push generator)
4  how metal halide street lamp  is build (usually  big glass envelope with e.g Argon inside  than inner tube (2 or 3 electrodes)  (the best with mercury inside)
That is what I suggest to take out and put into oil. with capacitor structure described by me.
We have utilized similar concept in caduceus+ coil capacitor( NYW group experiment in Lithuania)
5 HV circuit from presentation for me in Tbilisi but based on Gia tip of Tesla way of winding. He suggested that TK used    one of concepts ( left had side) in Glass Table Presentation
6 how Faraday disk works ( related to flat disk motor of TK)
7 Kodak flash lamp with  electrode outside the glass envelope utilizing electrostatic means  similar to Correa patent from point #10
8  TK flat disc motor  by Kellys book
Philips SAH-250-B Short Arc Mercury Vapor Lamp
10 correa 3 electrode evacuated  tube.
11 just Chinese junk .. do not pay to much attention to this one..
12 exposed spark gap in Bed  presentation of TK second one must be in the metal can described by me in this article
jbignes5
 Lets look at this picture more closely.Click the jpeg link to open it in a viewer program to blow it up to see the textures of the lines on the cylindrical winds. The outer coils are merely solenoids and they hook to either side of the capacitor coils in the middle. One end looks to hook to the buss bars in the plastic box. These should be the main spark gaps and fed into the solenoids around the three phase unit.
Try to think of this like they do with multiple motors around the center gear. In this case the gear is actually 3 in one. The center coils are actually triple layered. The lower band around a longer solenoid wind around another heavier coil. These layers are not connect at all only by induction. The outer drive coilds are pulsed to get the screw like electric field I have drawn.
I have marked a section with a triangle denoting the angle and speed difference between the two loactions 3 and 1. The angle of the 2 line is the conversion via field twisting angle. The lower coil of the center unit should be self terminated through the cap that is made inside the larger inner coil and heavier center coil. The center coil is the driven ciol and converter from very high voltage to lower voltage higher current.
There might be flat spiral wound coils below the external coils indicated by the multiple layers there. This should give the field a twisting field in my honest opinion.
The center coils are halfway into the outer coils fields. There  is a compression field coil around the base if the capacitor coil. The plastic forms are hollow plastic filled with oil to create a barrier against the higher voltage and should resist breakdown way better then any insulation between the two different winds. These self terminated choke coils will assist the twisting of the electric field in the center coils increasing the angle of the lower electric field. You could also think of this like an old motor to bike interface that used friction of a roller on the tire to impart movement. If the center copper conductor raises in current like it should from being exposed to an very intense electric field it should pump in reverse the more current you demand. This is a transformer action without the core.
I know I have a few errors in this lets see if you guys can help me finalize the concept. There seems to be shielding all over the device on the top. I can see wires and a weave type braining surrounding the ceiling.
cheappower2012
You guys throw a whole amount of information in, thats useless,
as in the tpu device,this also applies to this device also.
As said by Jack Durban (Jack Durban is an electronic engineer that worked for SM)of
SM(the inventor of the tpu)
He knows exactly how to build a tpu,if he wanted you to know how to build a tpu he would
simply tell you,conclusion,
he doesn't want you to know how to build a tpu.
This same thing applies to TK also,in the video where Westley was shown a device in
hes trip to Georgia,who was there but wooshman(from the green box video),
the active components in the box were hidden.The coil is a red herring,to fake you out.
If you guys did some simple experiments you would figure this out,it requires
a single wire passing thru ,under the big coil to make the device work.
Different windings are a trick to fool you,you guys need to look at the 2004 video closely.
TK uses tricks just like SM Has to prevent anyone from figuring out how the device works,I believe
this device is a lot more complicated than the tpu,will be hard to replicate ,But can generate a lot more power,suitable
for electric cars,because the strong EM field that this device creates you can be sure its use would be regulated.Part of how this device works  is basic electronics,a part of it will be a brand new effect missed by the science community,it is related to the tpu.TK like SM did not know that certain things can't work according to science so tried them anyway,its an accidentally discovery,althu he says its Tesla's work it isn't,just as the tpu isn't Tesla's work.
jbignes5
 on second thought the lower field might be inverted allowing for a cleaner meshing of the twist to the fields. Like the perfect mesh gear system. This allows for us to change the slippage by holding the conduit tighter, looser then tighter again. The rebound can be very much more then you put in. We do this through the explosive capacitor release mechanism of a magnetic filter to increase the density of the make and breaks. But these capacitors must be of the improved design Tesla even has many patents dealing with these special kind of capacitor. These type of capacitors are the real power behind this process. Match that with a resonantly tuned bucking coil and you have all the power you need. The conversion going to higher voltage from a coil can be very extreme. You you will get more out of the cap burst and Tesla states that plainly. He could extract any amount of horsepower from these special caps and bucking coil setups. How you extract that is from a split wound coils around each half of the exciter coil. one for positive and one for negative. In the middle they are shorted. or can be shorted to create a virtual ground plane. Negative and positive must short on either side to make a complete ground plane.
Another way to get this focusing of the field is to split the polarities via twists in the coils and attach each one to a small thick antenna. With the ground plane being a huge in surface area antenna. This allows both polarities to intensify independently and attract the polarity twords it's element via excitation of that electrode. This is the same process only more open to the environment around it. No swirling fields to effect the human either.  There are many ways he did his methods.
Someone mentioned that there is no increase in the voltage beyond what is expected in a normal transformer and with normal capacitors and you are correct. But you are forgetting the fact that the Tesla transformers are not normal. They are unique in design much like the bifilar coils or one way emitters or receivers.
I'm sorry but this is all Tesla's work. He made us what we are today and he tried to recant that mistake and inform us of the way out. I don't care what Engineers tells you about this process because it is not within the real of their teachings. This was an experimental discovery from a very dangerous event that was happening to the DC system after Tesla improved that. This discovery is of the condenser on the generator he used to even the blast out or surge. But he didn't realize this effect could kill men engaging the lines to the generator amd it was killing Edison's men. Thats why Tesla investigated this effect. He slowly learned just how powerful the blast could be by vaporizing wires with the force of dynamite. This is where the conductors mass comes in. A certain amount of mass must be there in order for the blast to not tear the conductor apart. Increasing the voltage into the millions was the only way to do this. You just nned to limit the current till there is no more to loose and the voltage will still climb up. Converting down after that enables the huge current he could manifest. This he found he could do through induction that he discovered in the ac inductive motor.
Regurgitate the blather these so called engineers puke up and you will go no where. Just like the system that hasn't changed much in over 120 or so years. We need to listen to this man Tesla.
