0 Members and 340 Guests are viewing this topic.
energia9
Quote from: jbignes5 on May 19, 2012, 09:49:17 PM
You used the example of nuclear reactors. Why don't you try to replicate that? Hmm a bit too dangerous?
You say energy but you really mean current don't you? Energy is a two way street. To have energy you must have voltage and current. As you slide the O
|--Voltage-----------O------------current--|.
.       -C<(------------------------)>-V
to the right the current goes up and when you slide it left the current goes down. This is the inductive process.
This means only one thing. Voltage when impinged by resistance does not impede the voltage value. This is why Tesla could do what he did. Resistance is futile when there is only voltage. Raise and transfer your voltage and then convert it in the device you are about to use. Yes there will be losses but if you look at the re-conversion process in the device you will see that somehow you have more energy. Why?
This works on many fundamental processes. When the world is looked at, heat and humidity gather and move in unison. This is weather exemplified. These are tied together by fundamental laws.
This is because of the nature of electricity to gather and hold itself together in a field. Ball lightning ring a bell (extreme case).
What about this example.
Take 2 12 volt batteries and parallel them then take 2 12v batteries and series them. Hook the negatives together and place a 12v dc motor between the 12v positive (negative of the motor) and the 24v positive (Positive on motor). What do you think will happen?
Answer: It's gonna work.
This is the way voltage works in any space. When you add current then you have big losses and no gains ever. With current you will get nothing but losses but convert all the energy into voltage or near all and amazing things happen. Especially when you properly design the device to utilize high voltages and make it safe to be around. With the addition of gathering voltage from the environment (antennas) You should have any amount of current after the conversion process back to low voltage and high current.
All of this stuff was experimented on by Tesla. If you read what has not been kept secret there is enough out there to get the whole aspect of the total of his work. Each patent reveals more and more information and to boot if you read the lectures he made in front of many PROFESSIONALS you will see he was pointing to the higher voltages. Why because losses were different(mainly corona leaks) but manageable. Tesla even goes to great lengths to reveal ways to shield this stuff from leaking out.
This is from the banruptcy court of warden cliff:
"The method was this: I had a 550-volt current with which I charged the condensers.  These condensers I discharged through a primary in the form of an arc, sometimes I also introduced in this arc a mechanical break of several thousand per second.  And I obtained a (perfectly continuous train of waves) as has been described in my patents.  The reason why I show the condenser here [Fig. 83] is that, that "condenser is" synonymous with undamped waves.  If I had shown the whole apparatus as arranged there, then I might still have damped waves; but whether I use an alternator or some other way of getting energy to that condenser, the condenser is usually there.  For instance, if I use an alternator, I shunt its terminals with a condenser in order to (magnify) the (current) in the (primary).  I then tune this circuit to the alternator, and magnify the current in the primary in the (ratio of the inductance to the resistance)!!!!.  Therefore, this condenser here stands for either method, and simply means that in this system, as is obvious from the description in the patent, the (waves are undamped!!!) because high rises of potential would (not) be obtained otherwise.  Whenever I wanted to obtain a (high potential), I had to observe these (rules!!!!!!!!!!!!!!!!!) in order to (force) the (potential) up to that value."
In all the device that have gotten very near OU they all had the high voltage and low current mode of operation.
My final word to you verpies is stop banging the numbers and start helping with getting a system that works first. Anytime you say anything it is always whats the in/out... Build it for yourself then you can demand numbers at will. Otherwise why don't you become productive and not impinge on the ones looking to explain this kapanadze system or even the yoke.
Hey Jbignes5,
can i ask why are you writing sooo much?  i try to read what you are saying, but its allways like a book,  i dont mean its bad,  but....  please dont take this in the bad way, im your friend not an enemy.
do you have some schematics & videos of your experiments?
i would love to see them
thanks friend
xenomorphlabs
Quote from: yfree on May 19, 2012, 05:43:43 PM
A few days ago I posted the message below.
Replay #11573
There is an interesting update in PJKBook on the Kapanadze coil on page 3-107:
http://free-energy-info.co.uk/Chapter3.pdf
"The main secret of the Kapanadze coil is the conductive ring placed within the coil. This is in contradiction to standard thinking; a closed conductive ring in a coil would normally create a wasteful shunt rather than be a source of energy. It is hard to believe that this piece of physics has been known at least since Meyer's experiments (around 1975) but it is speculated that Tesla and later Hubbard knew this as well."
The more I read this article, the more I understand it, the more I think that Bill has it right. Bill’s approach is physics based. This article is going to break the deadlock. Read it again and again, both parts. It is really worth it. I like the second coil in particular.
yfree
It certainly seems to remain completely unconsidered by most that TK has one conductor or a whole bunch of conductive materials inside his various coils ...
But that fact wouldn't fit some far-fetched theories
jbignes5
Quote from: energia9 on May 20, 2012, 04:47:11 AM
Hey Jbignes5,
thanks friend
None the less it is a valid question. I think it is a mesh of a lot of things. Frustration, Over Thinking, trying to be as clear as possible about a not so clear subject and Always looking for References.
I'm sorry to say that I have no video's of my experiments. Most of them were to teach myself of the processes going on. I have done a lot of work previously on energetic forum. Sadly the owner didn't like me too much because I revealed his real character. He is a salesman by trade and only uses the forum to setup sales events for the lucky guys who have something to sell. I am planning on making video's really soon to show my experiments but it will take some time because of my health. I'm pretty much stuck in my bed. Scoliosis is a terrible disease and I have had it ever since I was a child.
Since my future is bleek at best I thought I would tackle the motive power thing and design something that helps people who can not move anymore by their own power. Yes they have scooters and such but the charging times are very very extended. Something that could self power could be very very helpful to people who rely on electric transportation.
Off subject. Annealing Process. Check this wiki: http://en.wikipedia.org/wiki/Annealing_(metallurgy)
"There are three stages in the annealing process, with the first being the recovery phase, which results in softening of the metal through removal of crystal defects (the primary type of which is the linear defect called a dislocation) and the internal stresses which they cause. Recovery phase covers all annealing phenomena that occur before the appearance of new strain-free grains.[3] The second phase is recrystallization, where new strain-free grains nucleate and grow to replace those deformed by internal stresses.[3] If annealing is allowed to continue once recrystallization has been completed, grain growth will occur, in which the microstructure starts to coarsen and may cause the metal to have less than satisfactory mechanical properties."
Hmm the plot thickens...
jbignes5
 Subject annealing:
"The magnetic properties of mu-metal (Espey cores) are introduced by annealing the alloy in a hydrogen atmosphere."
This could be why the Russian yoke is different then others. Maybe a different annealing process was used for the yokes.Also it seems that we could re-anneal any core to our specifications, for those using cores.
I found something interesting about iron as well.
"Ferrite also known as α-ferrite (α-Fe) or alpha iron is a materials science term for iron, or a solid solution with iron as the main constituent, with a body-centered cubic crystal structure. *******It is this crystalline structure which gives steel and cast iron their magnetic properties*******, and is the classic example of a ferromagnetic material. Practically speaking, it can be considered pure iron."
Zeitmaschine
I'm using a HV-Transformer from LCD-TV back light inverter, currently driven by a Darlington BD645 and XR-2206 at 225KHz. This creates exactly the same purple noiseless tiny spark as seen in the Kapanadze videos. Nevertheless, the BD645 gets hot and needs a heat sink. Using a fan is not a mistake either. I think this is because the spark gap essentially behaves like a short circuit on the transformers high voltage coil.
Concerning Kapanadze's 9V battery: How do we know this is not a trick? Powering up all the modules and stuff (and empty capacitors) in the transparent box by means of a small 9V block? What is the little silver box for? Maybe this box contains an additional accumulator (recharged when the device is running) only triggered by the 9V battery in order to make it look more interesting.
