stivep
Quote from: stivep on May 20, 2012, 02:39:05 PM
This guy is to be the one who was holding patent on technology utilized by John Hutchison
transmutation and  antigravity
As we could assume energy is main component of our interest in this area.
Dr. Judy Wood - Where Did the Towers Go?
http://www.youtube.com/watch?v=ZWjktDuIhR8
Minute 1:07:53
One hour seven minutes 53 seconds
Find this patent by yourself
George Samuel Piggott   !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Wesley
http://www.youtube.com/watch?v=3AzAyTgUsWA
minute 2:38
Paul William Mueller
is on document of John Hutchinson  releasing Frequencies to the public.
Please find more
Wesley
stivep
Quote from: sadang on May 20, 2012, 04:29:45 PM
- U.S. Patent 1006786 - G. S. Piggott -- "Space Telegraphy"
or
- PowerPedia - Electrostatic generator
Thank you for  info about
Wesley
Is the a guy?
http://paulslab.blogspot.com/
The logic says that he is the one who was after  John if talking about chronology and history?
It looks like John was visiting this guy.
He has machining shop
Connection says something I have to get more info.
OK I got  confused :
The guy who show the document standing that J.H released frequencies to the public and the letter looks like is the same guy  Paul William Mueller and he has YouTube channel that he uses to present  documents.
Please review all of his  videos.
jbignes5
stivep I showed you the exact caps. They are Russian made and they are not cheap. They are used for load balancing of power systems. Even the configuration matches the shunt capacitor system. The only reason to use them is to balance the load to the power supply. They are very hard to set up and since the matal plate below it is attached to the flooring they just cut the wire to the exact capacitance needed because the caps are grounded (virtually or real) via a can bolt.. They had it initially setup for the motor(LOAD) not generator. When they switched to the lights the load type changed and they had to patch the shunt bank.
I watched the whole video and the motor was the first load and then they disconnected the motor and tried the lights. I bet it didn't work to well and they needed to adjust the shunt bank to match the new load hence the cut wire to the two caps in the right foreground.
Yeah the coil wires do in fact go into the cylinders on the bottom. I noticed this in the video with the blue coils video as well. If this indeed is the same system with improvement why don't you peek at the clear box to the lower right in the blue coil video. Instead of externally shielding the room you could statically shield each spark gap with that setup and there should be 3 bigger metal boxes with wires coming from under the lip. Why not through the box?
Also did you see the flat grounding strips to each box top. They all hook together..
cheappower2012
Zeitmaschine,interesting setup you have, you have to start with the assumption
that TK doesn't want you to know how to build hes device.TK like SM likes to put on a show
likes attention but will give you shit.So I agree he could easily put a relay as a start switch,the
9 volt battery enrages the relay
a bigger hidden battery is connected,that is also  charged when the unit is running,very do able.
TK like SM has an incredible ability to deceive,SM tactics are very similar to TK's however they make
mistakes,its thru the mistakes that you will find the answer.In my opinion the spark may not play a very big part
in the device,it would from a Tesla view point.Like the SM stuff you go back to the first tpu,in TK's case the transparent box video,
the spark produced seems to have a duration of about one a second,its not an high frequency ac spark,I don't know how you fit that into Tesla's stuff.
A lot of things in the box are to fake you out,not really functional,in my opinion.The coil producing the hv in the transparent
box video is a strange transformer,maybe a hv transformer with a built in rectifier for a foreign
CRT TV or?.This video shows that the spark does not have to be high frequency  or real fast in duration.
The kap coil is interesting looking too,different from later coils.
ronotte
Hi wattsup,
I think I've the answer to your question :) I simply forgot to tell you that in the past I've also bought 6 x SSR (Solid state Relay) from Jason Owens. After many thousand tests I still have with me 5 of them. You could use them for every switching applications: just swap the final mosfet with a properly selected one that is good for your current application. Standard mosfet are all the N channel IRFxxx devices. You have to note the max applicable drain voltage and resistance. They do not reach 5MHz but if I remember well there are no problem up to 2MHz.
SSR3A is composed by: a floating micro inverter for mosfet driver supply, an optical isolator for your input signal, a powerful mosfet driver and finally a  power mosfet bidirectional switch. All is well stable and well protected against transients,
SSR3A provides for a useful bidirectional switch: if you do not need it just take out the lower mosfet switch and short circuit with a jumper (on mosfet's socket) the Drain and Source pins. In this case the overall stray capacitance is also less so the BW increase.
I used them for low voltage/very low resistance (50 milliOhm) needings using IRF540Z or 1200V application....or standard 600V IRF820 High band width....I do know very well this unit (SSR3A). I suggest you to contact Jason...
Have fun
Roberto
