jbignes5
Quote from: verpies on May 21, 2012, 09:06:37 AM
Perhaps with a competing orthogonal magnetic field, such as in the attached patent.
Nice bipolar(??) mag amp you got there looks promising. Hey didn't a guy named Flynn do the same thing except with a motor design?
Ronotte also posted the schem earlier.        .                                      Wow how observant.......
.                                                      Sorry that was rude.
.        I apologize.
Did you read any of the previous 200 pages?
Oo a time warp. You reposted that after I responded.
.                              Lol, How tricky....
verpies
Quote from: forest on May 20, 2012, 03:29:44 PM
how to modulate magnetic field of coil completly...  on/off  ;)
Perhaps with a competing orthogonal magnetic field, such as the one in the attached patent.
Zeitmaschine
This is strange. The frequency meter shows 49Hz (for my understanding), so this is almost normal line frequency. Also the ammeter shows correctly the amperes running through the ground cable (5000W divided by 220V equals 22.73A). But oddly the voltmeter (same instrument as ammeter) is unable to measure the voltage due to »a field that influences«. What field could this be?
In other words: What strange wave form is needed in order to make an ammeter work but at the same time preventing a voltmeter from doing it likewise?
Let's say 220V AC from inverter is converted to DC, 220 times 1.414 (square root of 2) equals 311, therefore DC voltage is 311V on capacitor. Now this DC is converted back to 50Hz but wave form is square, therefore this is not really AC but chopped DC (duty cycle unknown, perhaps square root of 2 in order to get back 220V effective). This square wave then is influenced by the magnetic field of the helical coil where the spark gap fires approx. 200.000 times a second. Furthermore the 200KHz frequency is possibly synchronized with 50Hz frequency (or vice versa). Maybe using the term »resonance« is not entirely correct here and should be replaced by »synchronization«, because how to get resonance between 50Hz and 200KHz? Normally resonance occurs between (almost) same frequencies, not if one of the frequencies is 4 times 10 to the power of 3 times higher than the other (1).
Something to ponder about: The voltmeter shows a few hundred volts fluctuating and then it goes off the scale, meaning more than 1000 volts were measured. If the frequency of 50Hz is superimposed by a frequency of 200KHz and the frequency meter as well as the ammeter does not recognize this high frequency at all then they will display the correct value of the 50Hz current. If on the contrary the voltmeter responds to this high frequency then this could easily explain the seen voltage measurement error.
In order to avoid this behavior a filter could be used to get rid of the high frequency before it reaches the lamps. And yes, as a strange coincidence, in Kapanadze's patent specification there is mentioned not one filter, but two.
Just considering, I have nothing that works for the time being.
But after all I think it is time and Kapanadze should hurry up to give away the schematics of his device freely, because conceivably the principle of his free energy device could be taught even in elementary schools soon.
1) A variation could be to modulate the 50Hz chopped DC with 200KHz so there is indeed a resonance between the chopped 50Hz/200KHz DC and the magnetic high frequency field created by the helical coil.
jbignes5
Quote from: Zeitmaschine on May 21, 2012, 09:57:26 AM
I would like to introduce you to the electric field. It can mess with all kinds of electronics if not properly shielded.
I really don't think Kapanadze is gonna give this away. It's just mans nature to be selfish.
yfree
Quote from Zeitmaschine:
"But after all I think it is time and Kapanadze should hurry up to give away the schematics of his device freely, because conceivably the principle of his free energy device could be taught even in elementary schools soon."
Quote from jbignes5:
"I really don't think Kapanadze is gonna give this away. It's just mans nature to be selfish."
It has been given away for free by Bill McFreey:
http://free-energy-info.co.uk/Chapter3.pdf page 3-107.
Every working "overunity" device has to be a nuclear reactor, so far all of them were.
Just read  and understand it, please.
Best Wishes,
yfree
