0 Members and 136 Guests are viewing this topic.
Zeitmaschine
I would like to introduce you to the electric field.
Created by Kapanadze's helical coil?
If I see this correctly the frequency counter has only four digits separated by a fixed dot. This implies this frequency counter can only measure frequencies up to 99.99Hz (common line frequencies), but not thousands of Hz. Therefore it shows the 49Hz frequency and is not influenced by the superimposed (maybe) 200KHz high frequency.
The ammeter measures the amps by inductive coupling. This coupling is not suitable (deliberately) for high frequencies but only for 50Hz to 400Hz (maybe a little bit more). Therefore it shows 23A properly.
The voltmeter is connected galvanically (DC coupled) without any thing that works like a HF filter, therefore it messes up the voltage measurement.
Every working "overunity" device has to be a nuclear reactor.
Hence we should conduct such experiments only in heavy shielded laboratories, I presume?
jbignes5
Quote from: Zeitmaschine on May 21, 2012, 11:16:23 AM
Maybe this will help.
I believe you are right about the frequencies. This can be done via two circuits that are in inductive relationship with each other.
Remember each wire has an electric field in the form of lines around it. Check this extreme example of the configuration:
http://www.autoevolution.com/news-image/how-eccos-works-7639-2.html
This is the best example of what happens in and around a wire when the electric field is a major component. Each turn of the wire now changes that discharge. The picture is a view down a wire for example. This field also moves if the frequency is just right. The best movement is as close as possible to resonance.
I started to reread the problem of increasing human energy and I am now seeing the direction he was going.
http://www.teslauniverse.com/nikola-tesla-article-the-problem-of-increasing-human-energy
"The investigations led to many other valuable observations and results, one of the more important of which was the demonstration of the practicability of supplying electrical energy through one wire without return. At first I was able to transmit in this novel manner only very small amounts of electrical energy, but in this line also my efforts have been rewarded with similar success.
The photograph shown in Fig. 3 (see p. 186 shown below under first picture.) illustrates, as its title explains, an actual transmission of this kind effected with apparatus used in other experiments here described. To what a degree the appliances have been perfected since my first demonstrations early in 1891 before a scientific society, when my apparatus was barely capable of lighting one lamp (which result was considered wonderful), will appear when I state that I have now no difficulty in lighting in this manner four or five hundred lamps, and could light many more. *******In fact, there is no limit to the amount of energy which may in this way be supplied to operate any kind of electrical device.********"
Сергей В.
ПривеÑ, всем !!
Hello
As Stefan said about Energetic Revolution in 2012 now is time to to make a move close to it !!
Резонансный усилиÑ,ель мощносÑ,и СÑ,епанова Аркадий АнаÑ,ольевича
- Resonance Power Amplifier Complete Patents
Watch Videos
Stepanov transformer 1-3 (СÑ,епанов Аркадий АнаÑ,ольевич public presentation videos)
http://www.youtube.com/watch?v=Y8zSMXMo2hs
http://www.youtube.com/watch?v=fDRTdTJTgGc
http://www.youtube.com/watch?v=O3O2JahD67o
Самара Резонансный усилиÑ,ель - Another variant
http://www.youtube.com/watch?v=Ocn6IR9mTJI
Transtim Variant RPE (Variant of Stepanov RPE)
http://www.youtube.com/watch?v=tHz5diCnJww
http://www.youtube.com/watch?v=L8xL5rucJHo
http://www.youtube.com/watch?v=eA9jzKJqlCo
Yandex Video here
http://transtim.narod.ru/catalog/rezonansnii_preobrazovatel_energii/demonstratsiya_raboti_rpe
More info Transtim RPE here
Site: transtim.narod.ru
phone:
+375(17)39-100-39 и +375(17)39-100-39
Email: ppp1@transtim.com и transtim@yandex.ru
jbignes5
Hmm check this out. You can see the Kapanadze system in figure 12 well the receiver part anyways, which can be inductively used to power anything. All you need is a signal to lock onto to get the air gap(Tesla's words) firing.
www.tfcbooks.com/tesla/1919-05-00.htm
T-1000
Quote from: Сергей Ð'. on May 21, 2012, 12:41:54 PM
ПривеÑ, всем !!
Hello
Watch Videos
Where ar circuits for replication and confirmation of effects?
If there are none, it is just another TK like box for waste of time...
P.S. Sorry to be sceptic but this forum thread already is taking too much time with "chit-chat" of people instead of actual devices replication..
