0 Members and 611 Guests are viewing this topic.
verpies
Quote from: jbignes5 on May 24, 2012, 02:41:50 PM
It does not measure the true input. Only the Pin we define.
Measuring only the PIN we provide and POUT we consume, is sufficient to judge the effective efficiency of any device.
If there is any energy provided by the environment then it does not affect the POUT/PIN ratio in a negative way - it's only an added bonus that just makes it larger (better).
If however the POUT/PIN ratio is less than unity then we can be certain that the device that exhibits it is not OU, regardless of the energy delivered by the environment.
Thus it makes much sense to measure just the power PIN we deliver on purpose (as well as POUT)
P.S.
I will not respond any more to word salads.
sparks
     If you look upon the cosmic background radiation as stationary.  Then the speed of the Earth in relationship to this stationary thing is 600km/sec.  You send a laser to a point on Earth that is downwind the received frequency is blueshifted.  I think some experiment trying to proove an aether came back that there was no motion relative to space.  Wrong.  Now how do I get a coil to move relative to a magnetic field at 600km/sec.  First of all I need to get the damn magnets to slow down relavent to my coil.  hmmm  Or create a disruption that remains fixed in space and run into it with my coil.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
jbignes5
Quote from: verpies on May 24, 2012, 03:51:01 PM
P.S.
Really so the Pin in your definition is what?  Remember the capacitance of a wire varies according to Tesla... Plus your definition includes current. The only way to get rid of any loss is to get rid of the resistance and current. Both of which we can do! Measurement looses value because the scope or meter makes assumptions that a pulse is ac. It is not ac and is very different in it's actions. Any measurement with traditional devices would be fooled by the pulses. So this means the results are scewed. But like wise you could take those pulses and use them in a transformer to have the other coil (secondary) to provide the other half of the ac form! Capacitors become like static batteries being able to supply endless charge or flow over time and the transformer is the environmental tap.
Call it what you will word salad is the way I communicate.
This is a good example of scales of view or perception.
http://www.youtube.com/watch?v=_IVqMXPFYwI&feature=related
It's all relative and it's all dynamically growing in intensity. This intensity of the current network is condensing. This raises the ability to beyond light speed. It can effect the pathways and grow them stronger and fuller of this network. We can bias the natural field and make matter capable of tremendous abilities including our own bio electric field. Some people have realized how to connect to this stream and resonate with the target frequency, they access the stream and filter for the frequency. Using Tesla tech we could produce amplifiers for the bio electric field. They say we only use at best 10% of our brain mass. With acceptably to Einstein's 12%. We could learn to control this energy via bifilar sensors. Amplify via focusing of that field. There should be no problem with interfacing with the electric compressors especially since we are in our bodies this connection would be very electrical in nature. With our thoughts being very electrical in nature. On and off. The variation in between the on and off being like binary code and highly variable or dynamic. The on and off is a code and then the magnitude of the code = additional code or bits. This wishy washy on and off is the chaos theory.
verpies
Quote from: jbignes5 on May 24, 2012, 04:45:22 PM
PIN is the power delivered to the Device Under Test by its user.
jbignes5
Quote from: verpies on May 24, 2012, 05:01:28 PM
well what about what gets dragged along but not used? Or not measured for because we think it doesn't exist. It does exist and it is measurable and even manageable. We can reflect it and create bigger moves of inertia that take very long times to decay. Each successive wave reinforces the standing value. That value always balances itself and will overshoot it's origin almost instantly.. This increases the flows back and forth in a radiant manner. learn how to reflect that blast and you have all the power in the universe at your control.
