Magluvin
This is a vid posted by FreeEnergyLt of a setup with the coil wound around the capacitor.
http://www.youtube.com/watch?v=MJybhTzDzcQ
I just found a cap that I can try this with. Plastic container, not aluminum, as this is what I see in the vids. The metal can is probably problematic for this project. The vid above only shows the setup but not running.
But the previous vid posted that shows like 80 amps at low voltage, seems to emulate homopolar generator outputs.  Im wondering what is happening, in the cap.
Also, for some reason, in the vid above, it looks like a sparkgap/suppressor across the cap leads. If there is low voltage like in the first vid, then what is the suppressor for? ;]
Seems like a simple and interesting project. Looks like he is using a scanner light tube neon circuit to drive the coil through spark. I have a few of those.
Mags
trawnik
dxer_87
Wow, I can see someone in my country made kapanadze, good to know. Interesting way of making spark gap, the crocodils are glued to the plastic right? Which schematic are you using? Would gladly connect this machine to my heat radiator and smell some sparks :D
Przemek
verpies
Quote from: Zeitmaschine on June 03, 2012, 09:25:58 PM
There is another flaw: The Kapanadze coil has with almost absolute certainty no ferrite core and there is no evidence the SR193 device is not fake.
Hence all this could be easily a »red herring«.
It may be but it's the best explanation I have seen so far ( only with two flaws ;) )
BTW: I have never seen the SR193 device.
