0 Members and 115 Guests are viewing this topic.
verpies
Quote from: frantz on June 16, 2012, 04:07:11 PM
Don't create theory, just check by experiment!!!!
Check two setups:
1. Two TC transformers vertically
2. One horizontally second vertically.
I don't create theories - I confirm and cite them.  See Near and Far Fields
I played with Tesla Coils when I was 11 years old, but I still remeber how they behaved.
This article correctly predicts the near-field interaction between the perpendicular as well as parallel configurations of the receiver and transmitter coil / antenna.
forest
Quote from: verpies on June 16, 2012, 04:52:56 PM
would it be the same if connection is via single wire transmission line ?
verpies
Quote from: forest on June 16, 2012, 05:16:53 PM
I have not analyzed this case.
The wire would extend the near-field range - especially the unbalanced electric charges
sparks
   A tesla coil is an ends to a means.  Believe you me there is no coupling of anything to it.  Tesla was not producing em waves or standing waves or any of that unless he wanted to.  He was playing around with the permittivity of space itself.
You change the permittivity parameters of space and electrical charge residing in that space reacts as well as the rest of the fielf.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
jbignes5
 A Tesla coil is only part of the equation. It's the first part. Once you have the blue flame coming out of the tip I would think you could energize anything including unshielded caps. Listen guys the reason you want to raise the voltage as high as possible is to change the character of the current. It becomes less of a loss the higher it goes, at least from resistance and resistance is a big stumbling block. Once you have cleared the current waste then it is now time to time the pulses and create a one way valve. In steps the spark gap. once the spark gap is done then comes the low resistance winding that will get excited from all the pulses. This gets radiated inwards through the copper of the load coil and energizes anything it touches. By going inwards the field gets more intense or compressed and the charges that are getting sucked from the ground loop is attracted to the high voltage area. All the while this field is spinning and churning swirling the heavy charges through the load coil and generates a very good current flow as well as the exciter voltage to a lesser degree......
Once the ground loop is there it can take a very long time to dissipate as stated from the earlier ground loop reference I posted.
"Real grounds are conductors, so there is a certain
amount of resistance to electrical current between all
grounding points. This resistance can change with
humidity, temperature, connected equipment and many
other variables.  The resistance can always allow an
electrical voltage to exist across it.  Large currents
running through grounds will cause voltage drops in the
ground conductors and will take time to dissipate."
These loops are not limited to the real ground as well. They can form from any virtual ground even.
There is no magic just something they thought was a nuisance. They even say these current don't really do anything bad.. Well I beg to differ.. Many transformer fire are fed from ground loops and it doesn't take a rocket scientist to see whats happening. Ground loops take a while to fade and thats usually why they leave them alone till they run their course.
The one thing Tesla did figure out was that energized fields enhance current flow of all items in that field including us, when the voltage and frequency are right the current flows very easily. Maybe because the pathways have been enhanced by the energizing voltage field. Maybe bridging the resistance and effectively allowing the current to pass unimpeded.
"Ground loops allow electrical and magnetic interference to create noise voltage sources.  These
voltage sources add to the signal being measured and are indistinguishable from the proper
signal.  The controller, not knowing that it is reading an improper value, performs an improper
control action. This can result in uncomfortable conditions for the occupants. It can also drive the
mechanical equipment into an oscillation, causing the equipment to wear out prematurely.
The primary sources of these noise problems are Magnetic Induction and Ground Imbalance."
