0 Members and 74 Guests are viewing this topic.
cheappower2012
I told you guys that TK will not give you shit,I also have told you it is not a Tesla invention
only has aspects of some of Tesla's parts.In my opinion the ground connection does nothing
its there to fake you out.
The cheap clamp meter used reacts to the  high frequency pulses induced into the wire coil,
This effects the voltage measurement in the greenbox video across the lamps also.It seems to
me that you guys want it to be a Tesla invention,like the tpu crowd,that believes that SM
the inventor of the tpu,can't lie ,won't lie and is going to give it to them.Here is a challenge,
give one example where a
condition as in the picture I'm posting ,has a current flowing
of 25 amps ac 50Hz/60Hz.Giving examples of high frequency lighting a bulb with one wire is
not the same thing
the clamp meter has a limitation factor,it can't measure high frequencies.Examples of
static discharges involving
dc ,is not the same as ac currents at 50Hz/60Hz.I believe that in the TK device your
dealing with an unknown principle,
principles can't be patented,this is why TK will never say how to build hes device
or patient
a clear patient ,because.Once known you could make a variation of hes device and cut
him out of the picture,he knows this,
that's also why the applied patients are not clear,by design.A lot of TK's tactics
are very close to SM's,to hide all information,connected to hes device and give you nothing.You guys need to look
at the SR193 video again,I believe there is a good chance that its real,althu I think SR193 hid things also so
you can't replicate it without a lot of research and experimentation.
This is the direction that I'm going ,replication of the SR193 device.
jbignes5
I will say this one more time. TK's device has 2 grounds period. Learn to watch videos with open eyes. One radiator buried and the water pipes. How blind are you?
Good bye all,
Stivep, Itsu I'm sorry but I need to be with my family and can not waste time with uneducated people like this. I hope you understand. I'm still reading this but I just don't have the time anymore to waste.
@Itsu if you need help with the project let me know via pm I'll try to check everyday at least once.
stivep
jbignes5
Your devotion to the subject was proven well
Thank you my friend for all of the help.
Wesley
Zeitmaschine
Quote from: cheappower2012 on June 28, 2012, 05:01:37 PM
Then all we need is a cheap lamp which also reacts (lights up with 25 amps) to the high frequency pulses induced into the wire coil. ;D
This is ridiculous: an old man throws together some used TV parts from junkyard with a sledge, gets free energy to power the world and no one can figure out how this works. Where are all the studied scientists? They can split atoms, but have no idea how electrons really work? What do extraterrestrials think about that? :o
Quote from: Shokac on June 26, 2012, 08:50:44 AM
use this schematics for automatic resonance TC
Looking at the two transistors I ask myself, does TK actually need two big transistors on two big heat sinks with one big fan in order to create one tiny spark?
Victor Grig: »Put the incandescent light bulb in a coil connected to a high frequency circuit and the light bulb will light up without applying any potential difference!«
I have the distinct feeling we are missing something important here.
cheappower2012
Instead of fighting with me,give one example of one wire allowing
a current of 25 amps ac, 50Hz/60Hz to be shown on a clamp current meter.
The 2004 video shows one ground wire,you guys need to get it thru your heads that TK is a showman,
part con man,hes a very smart guy as is SM inventor of the TPU,however there full of deception,
although TK is nowhere close to SM in this area.The reason no one can build either a working tpu or TK's device
is because there's an unknown principle involved,the reason TK and SM discovered this is because of
luck and they experimented with different things,an educated person would say this can't work so won't try it,TK and SM
would try it.I posted what happens when a high frequency is introduced into 60 Hz ac,you create  errors in voltage measurement,including errors in current measurement,this comes from the particular cheap clamp meter used,however if  you choose to ignore this then like the TPU people you will go in circles and get nowhere,because TK is never going to give you the information,I suspect that's its very strange stuff,which is why no one has figured it out.
