0 Members and 483 Guests are viewing this topic.
baroutologos
Hello admin, Thanks.
What do you mean by syncronization of the TC output? Actually i did not syncronize the output. I only harvested the output via a FWBR and cap storage or directly to resistive loads after stepping down it again with same specs Tesla coil inductor. Or by inductive coupling.
You suggest the resonating TC to pulse an also resonating output (large capacitance small inductunce) that will harvest the energy via a third coil? Two resonances in a row?
No, I have not done that. but if the first resonance via single wire energy capture  (TC-FWBR-GROUND or TC-TC-BULBS-GROUND) or inductive coupling is not giving any OU, why two resonances at row, even syncronized to give?
By the way, my ground connection is the water pipes. As far i can tell that is a good ground and the TC operates fine.
xenomorphlabs
Quote from: baroutologos on April 01, 2010, 04:43:47 PM
The water pipe system can sometimes not reach the earth at all if PVC parts are being used at the basement level ,what you usually can´t see.
But doesnt have to be.
Most likely also not the cause for it not to work alone.
forest
Quote from: Cap-Z-ro on April 01, 2010, 04:11:05 PM
Quote from bart...
" Thus the magnetic field influences the "unknown energy" and it is transmuted to useful electrical one? Why not to heat? And if so via what procedure? "
That calls for a quote from the master of magnetic energy(using steel by the way)
" You've got to ring the bell "
- Ed Leedskalnin
Regards...
That one ? http://upload.wikimedia.org/wikipedia/commons/9/95/Electric_Bell_animation.gif
Nooo...... can you find at least one doorbell schematic on google , Ed was talking about ?  :P
baroutologos
Xeno, you are correct on that. but what i say here it means i have checked it ;)
Mine ground BTW (water pipes) are really ground because, while i was experimenting on some Gray tube concepts, i saw that i can run bulbs directly from one wire 220v mains (the hot wire) and the other the real ground (water pipe)!
No to mention the vast difference of lamps intensity by using 75 watts lamps and Kacher with and without ground usage.
Pirate88179
