0 Members and 163 Guests are viewing this topic.
cheappower2012
 Virtual grounds,I don't see a ground,can't find a ground
so it must be an invisible ground or a  Virtual ground. ::)
A motor in a can,primitive and disappointing :o,a motor that's a generator and runs its self,wow
where do you guys get this stuff from ,very creative,crazy stuff ;).
Tk's device is powered from a place miles up,somewhere close to 60 miles up,  Schumann resonances,
at a frequency of 7 HZ  to 16 Hz,the energy content of a wave is determined by its frequency,
the waves at 7Hz to 16Hz are very,very low energy,that can never explain the power of TK's devices.
stivep
Quote from: cheappower2012 on July 03, 2012, 12:55:20 AM
Well invisible ground is either hidden ground or artificial ground  means  virtual ground.
The term is perfectly technical.
virtual ground is counterpoise for an antenna
http://en.wikipedia.org/wiki/Counterpoise_(ground_system)
So please please speak  English here.
QuoteA motor in a can,primitive and disappointing :o ,a motor that's a generator and runs its self,wow
where do you guys get this stuff from ,very creative,crazy stuff ;) .
Why not, you see can being hold with epoxy so it do not move from its original place :)
if motor is to be a dirty signal generating element than look at the schematic below ,
I know that this is simple and primitive assumption but we do not expect from TK to build space craft.
I agree if  and only if we use Natural incoming frequencies from Shumann effect.
Bu if we assume presence of the transmitter that was placed somewhere to  transmit at frequency of Shumann  resonance than is different story...
or as we know that
telluric current that exist in the earth and was used commercially in 1858 as FE. That Telluric current is  product of ionosphere earth interaction. And as space between  ionosphere and earth is a waveguide for Shumann  effect than there is the place where we should look at presence of naturally accruing transmitter
Picture with 2 motors is  only graphical presentation of transmitter receiver
But when transmitter stops to transmit  for interval of  few cycles than  receiver becomes transmitter  returning  energy back to motor that act now as receiver.
Non saturating RF choke :
this is  iron pipe with two magnet discs  on the sides that was another crazy idea from Niko
as he was taking color of the discs (black) as presence of magnets.
since ferrites can not be used and  in regular  CRT TV every TV has this kind of choke ( just take piece of  metal or  screwdriver and try to stick to this choke... you will find out that  I did not discovered  "Amerika."..
Again this kind of choke is in every TV.
Wait a moment..........
Why choke in my TV has magnet not on the top of the coil but round disc that is on the side of the coil??????? hm.............( in my TV with CRT tube ,magnet disc is in diameter of the length  of the coil and is not placed  coaxially edge of that  circle is touching  edges of  form of the coil)
TK told me that he  found something interesting and that is why he start to experiment with it........
I was trying to explain only one element of the schematic here. It is 3:32 AM  ...I'll better go to bed and rest  will be added later.
So  why they did not use ferrites in TVs ??? ??? ??? ??? Because ferrite  saturates..
The coil 1,2, is secondary coil  that takes all of the impurities and there is spark gap adding even more impurities than  look where this coil 1,2 terminals are connected.............
to primary of the transformer.. than  in effect  most of it is going to end-up in motor...
That acts as self regulating  circuitry...
In red  box you have capacitor and coil (just marked with  red box but not explained on the picture)
That is a coil winded on capacitor ( preferably vacuum capacitor or ceramic)
The first transformer on the left  UPS [ with 3 legs on primary is our  12V from battery to 220V converter ( inverter)]
Counterpoise reverse antenna
This is like antenna ups side down........... flipped ..........
What was to be ground or artificial ground or counterpoise  or balance = now it is antenna
What was to be an antenna = becomes  ground or artificial ground or counterpoise  or balance
Wesley
cheappower2012
@Stivep, I 100% disagree that the energy the TK device gets is by
waves,so in my view you don't need a ground.I further believe that only certain parts
are related to Tesla.The motor in the can may be possible as a sort of pulse generator.
Like the tpu people
that believe certain things the tpu is a Tesla invention,the inventor can't lie,your not going to change your opinion,and I'm not
here to change peoples minds nor do I care to do that
but to acquire information on TK's device for my own research.A question for you,
the helper in the greenbox video,that held the box,I think hes name is teto something like that,
has raccoon eyes,what relation is he to TK,isn't he the one taking to you
when you looked at the TK device in Georgia,didn't he also make the device under TK's instruction.
Althu I think that TK is part conman,why did the people in turkey drop TK's device that
is strange do you know more about that.
dllabarre
Wesley (Stivep)
What is inside of Green Box?
What is inside of plastic box on top of 200 watt device?
DonL
