0 Members and 450 Guests are viewing this topic.
stivep
MACHINE SHOP TIPS #87 Identifying Metals Pt 3 tubalcain
https://www.youtube.com/watch?v=LVuJ7Y4qjA4&feature=player_embedded
TK table material identified:
questions:
1.is that material on the TK table only for the purpose of making few soldered points?
Or
was that any additional purpose that this material in such large quantity was present on the table including forming tools hammers and so on?
2.What he need hammers and other forming shape tools for if he was just trying to make few soldering points?
3. On picture named: Wesley's files - TK table material and tools identified 3 - this is picture from Tariel Kapanadze table..jpg (108.12 kB, 1280x960 -
what is the material placed on dish in the middle of the picture.?
QuoteWesley's note
Note:
using led of much higher melting temperature indicates that can might become hot inside.
using copper wide  strip  soldered with led   indicates that can might become hot inside.
SWITCH from the top of the can is in vertical position indicating that its primary use was not to flip position.
SWITCH  is mounted with additional thickness copper plaster. for temperature dissipation.
Where is soldering  iron on the table ?
I still have some problem when comparing  cylinders of TK table ( COLOR OF IT) to led of random shape on the same table.
Cylinders  a more black ( indicating that have been  made from different material.)
Cylinders look like  are of diameter of  metal can used by TK in experiment.
The last pictures are from collection of TK table pictures.
Wesley
x_name-41
Wesley, Wesleeeey was a what are these shenanigans? Please essentially we do not bothers with unnecessary details!
p.s. sorry for my brokken english because i use google translator!  :)
stivep
Quote from: x_name-41 on August 04, 2012, 01:36:01 PM
Answer the questions in the  post of mine and you will find what was the purpose of it.
but I have question for you and this is very important question:
Is the can of TK getting hot when the device is on?
just answer this one for me.....
Wesley
PS: the switch is in vertical position and that can not happened with switch like that.
That might say that  switch is broken ( not used any longer) or altered to serve different function.
For that response I did use one  of my  photos so do not concentrate on red  circle marks.
Zeitmaschine
Quote from: Ganzha on August 03, 2012, 10:28:52 PM
That way you choose - to research a junk on tables indicates that U R in desperit position, no fresh idea, nothing, that means END of researching.
Some EMF stuff to research:
METHOD OF IMPLEMENTATION OF UNILATERAL INDUCTION
Back EMF or negative electricity
Some more stuff to investigate:
1924 Practical Electrics - Tesla Coil
Replace the spark coil's batteries with TK's power supply (big diodes), replace the manual switch with TK's humming noise (automatic interrupter) and perform many wonderful experiments with it. :)
And it's time for some more flashbacks:
Forgotten Tesla Technologies
BTW: Melting furnace in TK workshop looks to me like ordinary table lamp. ::)
x_name-41
Quote from: stivep on August 04, 2012, 02:20:45 PM
Wesley
If powerful inductor emitting RF magnetic field, the watch on the hand Tariel Кapanadze would be hot when he approached  his hand to the inductor and would withdraw his hand but it did not happen, actually does not mean that it is not used. So to your question I do not think the device is heated in process their work.
QuoteRe: Капанадзе 4 1 день, 15 ч. назад #74571 x_name41
Hello comrades, do you think of the patent on the green box Kapanadze mentioned that in the first creates a large high-frequency magnetic field in the first coil (corresponding to the high-frequency heating coil (possibly modulated, and phased or synchronized with the frequency of the inverter it is 50 Hz.)) That affect the second coil forming a low frequency and weak field (from the phase inverter voltage 220v./50Hz.) and the difference between them is formed by the third field are removed from the third (or second) output coil.
