0 Members and 195 Guests are viewing this topic.
cheappower2012
Zeitmaschine,your still locked into its a Tesla invention OK,but your
question about the blue inverter is a very good question.
My guess is that the blue inverter has a small isolation transformer
1:1 ratio,gives the inverter a higher voltage than that produced by
the inverter output
however the transformer is loaded down when connected to TK's device,so
buzzes.The blue inverters output maybe  a modified sine wave
so the ac direct voltage will be higher.
There may also be adjustments on the blue inverter to increase
the direct ac voltage to much high settings,an operators manual or a schematic is really needed.
captainkt
Hi all, just a quick note for people asking about induction heater, if you put a coil between the heaters induction coil and steel plate, draw of power from thart coil then the steel plate does not even get warm. I can put hand on plate whilst pulling 3kw, take coil away and steel plate glows instantly red hot. Also the induction coils on all three types of hobs I am using do have built in ferrite strips underneath them, approx  2 inch by 1/2 inch by 1/8 inch x 6 off, possibly to direct induction upwards or increase induction I am not sure.
Keith
captainkt
@cheapower2012 If its of any relavence none of the three induction heaters operate(heat) when using a modified sine wave inverter. They light up and look as if they are working but no heat not even warm,plug back to mains and instant heat.
Keith
Zeitmaschine
Quote from: x_name-41 on August 04, 2012, 04:10:30 PM
Tariel Kapanadze - green box_ patent _rus.pdf
3 - ПрерываÑ,ель means »circuit breaker« or »chopper« NOT »Points (as distributor of an engine)«
Nice to know!
Thus almost for sure there is no flyback for high voltage creation in TK's tin can.  But this does not mean it will not work also with a flyback instead of a circuit breaker or chopper.
Quote from: cheappower2012 on August 04, 2012, 05:09:21 PM
Could be Tesla caused his invention to vanish for some good reason (Tesla's electric car).
More strange things:
PUMP Hub scattered electromagnetic (EM) ENERGY
Ideally, if this theory is correct, this device will allow, concentrating, greatly increasing the potential of this very weak (low intensity) of the electric radiation, use it as an "unlimited" free source of clean electricity.
In the "worst" case, the energy is received is not in unlimited quantities, but in some kind of limited. But it will at least clarify the above theory and to gain new knowledge about the nature of the physical vacuum.
And if there is no error, and the flow of energy in the system occurs, it comes across that he is from the surrounding space. It is quite probable that comes into the system is the electromagnetic energy of virtual particles.
Is this description just a coincidence or has Eugene M. Efimov (Евгений МиÑ...айлович ЕÑ,,имов) discovered the Kapanadze secret independently?
a.king21
Quote from: stivep on July 30, 2012, 11:41:12 AM
Let me give you what is below" it is" :
"Just imagination, say sort of Fairy tale "
Suppose that there was 4 old retired Russian scientists.
they  are not alive any longer. :) or say  very much dead!!
If any one find names of the four scientists I may give to the first of you who give me convincing information  $1000 and I'm very serious.
note: information must be convincing!!!
If there will be more information than only  4 names and   that would match their  involvement.
than I will ask OU community to donate to this individual more ,depends from usability of that information  to our movement.
Names of the  four  scientist will be released to the public. And OU community around the world will be ask to investigate anything about them that could be found.
I will not comment on my  "fairy tale" more till the time comes  to say more.
for whom this note is addressed  my "fairy tale" would be clear and understandable
Wesley
I'm sure she knows:-      E.a              R........e
