0 Members and 191 Guests are viewing this topic.
Acca
To Wesley:
here is video clip that shows a HV spark igniting a noble gas in a sealed cylinder and causing a quantum expansion of that noble gas. What is interesting is that the cylinder has to have a magnetic pulse to choke that noble gas first at the same time to cause this expansion to happen, the ratio is 5 to 1 in the expansion of the volume as the cylinder is hermetically sealed.
It seems that the spark and the coil pulse have to be in sync to generate the effect in the TK device as given in the example above..  As far as this company they have showcased their noble gas engine effect at the Tesla Tech 2012 last weekend.. Just a thought as I am working in these pulsed magnetic fields.. Joe Papp was a Hungarian inventor of that effect..
http://www.youtube.com/watch?v=y8V7yfycBNg
stivep
Resistor Thermal EMF (Vishay Power Metal Strip® Product Demo)
https://www.youtube.com/watch?v=AmAD_MFFJCY&feature=channel&list=UL
http://www.vishay.com/docs/30175/thermal.pdf  (50 mili ohm)
QuoteA thermal EMF is a very small voltage in the microvolt range
(μV) which is produced due to temperature variations across
the resistor.
Thermal EMF is an important consideration in
the low ohmic value resistors used in DC circuits and in
particular current sense resistors.
Thermal EMF has no
importance in AC circuitry. In particular, the importance is
found in current sense resistors since the thermal EMF
voltage could be larger than the desired sensing voltage.
I would not  agree  100% with opinion of that commercial statement from above in regards  to word
Quoteno importance in AC circuitry.
But flat brains can have PHD title in some cases as well. I do not blame them for that.
what puzzle me is junction area.
hmmmmmm... metal strip on the TK can
( bed experiment)
http://en.wikipedia.org/wiki/Electromotive_force
QuoteDevices that can provide emf include electrochemical cells thermoelectric device ssolar cells electrical generators transformers, and even  Van de Graaff generators
In nature, emf is generated whenever magnetic field fluctuations occur through a surface. An example for this is the varying Earth magnetic field during a geomagnetic storm
acting on anything on the surface of the planet, like an extended electrical grid.
addition #1 to the post:
Resistor Power Coefficient (Vishay Power Metal Strip® Product Demo)https://www.youtube.com/watch?v=YTh_7wx4Kug
QuotePower coefficient demonstration for power metal strip resistors. This demonstration compares Vishay and a competitor device and shows how the TCR and self-heating of a device affects the resistance value of the part.
what is important here is only part of rapid temperature change influence.
addition #2 to the post:
Power Inductor Saturation Current Performance Test (Vishay IHLP® Product Demo)https://www.youtube.com/watch?v=tYcUzVt-rvM&feature=channel&list=UL
addition #3 to the post:
Resistor Short Time Overload (Vishay Power Metal Strip® Product Demo) https://www.youtube.com/watch?v=3FFGcUNdfH4&feature=channel&list=UL
Wesley
PS:
Acca  I just woke up.. I did not review your material as of yet. thank you my friend.
x_name-41
I think that one way or right way to create effective free energy device is a transformer with unidirectional inductive coupling, or some kind of an analogue of the diode which transmits a magnetic field in one direction only (from input to output winding)!
stivep
Quote from: x_name-41 on August 05, 2012, 11:07:10 AM
I know that sound weird. But this is what I have in mind
can someone  make experiment:[/glow]
metal disc on the shaft of the  fan taken from  old computer.
1. blades of the fan  made of metal ( try different metals) ( could be dielectric as well as part of condensing  static electricity structure)
2. fan is placed in metal tube           (similar to TK can.)
3. from one side there is coil
a. 220V 50Hz driving  voltage on the coil.
b. regulated voltage and frequency.
From the other side of tube there is another coil but HV coil that means that coupling is done true blades of fan in the middle .
The ratio of coil one to coil two is acting as transformer
with magnetic field chopped.
You may try ferrites with coils  especially with   output coil on the RIGHT side of  drawing.
I did not specify yet  in my mind if we want to chop
1. magnetic   flux
or
2. electrostatic field
or
3. both
if
ad.1
than 220V on first coil is  enough.
if
ad.2.
than first coil on the left should be HV coil as well. but not necessary .We have presence  of  ionization field in the can with insulated road in  radioactivity......... non radioactive  probe sentilators
Simple ION chamber
http://www.youtube.com/watch?v=FRFgZTDjqTc
O boy.........
There is something in it for sure.
That what is above is me. I have got this  idea but
when I was looking  just now on  relation of magnetic field  chopping effect  using blades I found this
and that is not my idea but might be interesting to think about it.
that idea is based on patent
http://www.google.com/patents?id=Lv4FAAAAEBAJ&pg=PA2&source=gbs_selected_pages&cad=4#v=onepage&q&f=false
http://www.google.com/patents/US6194798
At the end of our journey to freedom .....from energy merchants and manufacturers.
that is not important WHO but it is important to deliver it  before the very end of 2012
I want to see powers of the world reaction.
Wesley
AT THE END OF IT CAN YOU JUST REALIZE SIMPLE  VERY SIMPLE TRUE................?
TARIEL KAPANADZE WAS AT FIRST EXPERIMENTING WITH  MOTORS
AND THAN HE  MADE TRANSITION TO "ELECTRIC DEVICE"
CAN YOU JUST LOOK AT THIS DIRECTION AND SCRUTINSE  ME
PLEASE?
Wesley
x_name-41
Hi Wesley, i posted here my circuit vision of Tariel Kapanadze device (based on transformer with unidirectional inductive coupling)!
