0 Members and 135 Guests are viewing this topic.
a.king21
The braid was disconnected for a few seconds and the device continued to run.
The 2 kw heater was not tested but emitted full heat - no question.
The  spark gap is a lightning arrestor. It is used as an overload protector.
His device is in an infinity loop. The output feeds the input which in turn increases the output.
If you don't stop this reaction it will eventually result in a melt down.
The spark gap is there to stop meltdown.
I have spoken with Magnacoaster's technical man Don, and he says Richard Willis was forced to remove his spark gap
because it failed radio emission regulations. This has caused Magnacoaster nearly a year's delay as they developed an acceptable circuit to deal with infinity loop overload.
There: I have coined a brand new electrical term " INFINITY LOOP OVERLOAD"
So TK's device is years from commercial realisation. I told him this on many occasions.
I blame his not very bright son and the two twin sidekicks for misleading TK and leaning on him.
They are too thick to see the way business is done in the West.
They are going to miss out big time because the E-cat is probably less than a year away from consumer roll out.
Magnacoaster also.
I told TK this is his last chance. I suggested air-conditioners to him. He has broken confidentiality.
Even if TK decided to play ball today, he faces years of consumer testing. He is 5 years behind Magnacoaster and 5 years behind the E-cat.
Because of his need for money he behaves like a scam artist - asking thousands of dollars for a demo and then not doing a deal.
He thinks that he is the only one who has found this phenomenon. Magnacoaster is very similar - probably  the same principle.
That is why I think Jack Noskills is close.
TK is also a tax evader and registered as unemployed, therefore stealing whatever passes for state benefits in Georgia.
I am sorry having to play dirty, but he has wasted 8 months of my life.
Guys and gals: Can you identify some of the components in the pictures.?
The good news is I believe the device is real.
27Bubba
a.king21
Quote from: balphom on August 08, 2012, 09:07:33 AM
can somebody explain how to build a circuit then ground it and measure the power going to ground that marches the load before saying that this device is a scam.
I never said the device is a scam. TK behaves like a scam artist.
Just because you have something everyone wants does not entitle you to make false representations.
The best thing for TK would be when Magnacoaster finally gets commercial rollout going. Then he is finished.
Menawhile if we look at both patents, ignore all the stupid false circuitry and concentrate on the transformer - which is never seen - maybe we will get somewhere.
The similarity between Magnacoaster and TK is that both have a coil pack (ie transformer) as the access to energy from the aether.
They both defeat Lenz. That is why I believe Jack Noskills is close.
Frederic2k1
Quote from: a.king21 on August 08, 2012, 01:05:04 PM
Is unilateral induction which is mentioned here 2 pages ago the way to design the transformer ?
verpies
Quote from: TinselKoala on August 08, 2012, 12:28:23 PM
It's also necessary to know how was this full heat measured, i.e. just because a load is rated 2 kW doesn't mean it's being supplied with enough power to dissipate that much.... even if it's glowing nicely.
Yes, power rating and the actual power dissipation are two very different things.
To be meaningful the brightness or color/temperature of the heater's glow should be compared when supplying it with known DC.
