0 Members and 71 Guests are viewing this topic.
a.king21
I suspect the device is based on ferroresonance or stochastic resonance. Both are known overunity systems.
The most significant part in TK's patent is the frequency generator.
IT IS THE MOST IMPORTANT COMPONENT.
He freaked out when he saw our frequency analysers. "You will know the frequency the device is based on" he screamed.
We are close -  very very close.
The frequency generator in tank circuit L1 is the resonator.
One of the coils in L2 is Resonated. It is not normal induction as taught in books.
The resonated coil then acts as a current amplifier. This coil is not drawn in the patent but is called a current amplifier - which is CORRECT!
I suspect TK detunes the resonated L2  current amplifier, so that it does not self destruct. Instead he loops the output back into the input and uses the common ground to maintain resonance.
We are very, very close.
Zeitmaschine
x_name41
Maybe if  used a one wire which to transmit and mixing high voltage and from network (inverter) 220v./50hz., in combination with this schematic or other source of high frequency power magnetic field (strange coil in back to blue coil?)
frantz
Quote from: a.king21 on August 10, 2012, 12:33:35 PM
I can't to agree with you in 100%
Are you suggesting there is only one some magic frequency for ferro resonance?
If you will have different core (M2000 or M3000), you will have different frequency.....
I think, TK afraid, you will see the shape of the signal.
Why nobody from visitors can't to connect oscilloscope to the output?
I'm afraid everybody will see some signal similar to this which I draw previously.
Question to all,
anybody saw some ferrits in TK movies with some the appropriate size of the core to the power?
Maybe flayback transformer, that's all.
I apologize for my criticism, but ... I would like to find answers, too... ;-) do not be offended at me.
Zeitmaschine
Quote from: x_name41 on August 10, 2012, 12:44:00 PM
When the high frequency can nowhere go but from primary coil to secondary coil and the secondary coil is lamp circuit with 50Hz and then a little bit of Rhythmodynamics come into play then perhaps something could happen. But not sure if it is OU that could happen.
