0 Members and 539 Guests are viewing this topic.
a.king21
Will get back to you later as have to go out tonight.
Resonance is absolutely required, but it is easier to obtain than we think if we use the right tools. Will explain later.
frantz
Quote from: a.king21 on August 10, 2012, 02:26:48 PM
Maybe you have right. I don't know this. Maybe you have better knowledge like me.
Put everything what you can, please. Maybe we will be wiser.
Thanx a.king.
Frantz
Hoppy
Quote from: a.king21 on August 10, 2012, 10:25:46 AM
I object to that comment. Genuine people with representatives of the British government were there to see the device. This is the most solid proof to date.
Do you know the names of the British Gov reps and their dept?
Hoppy
x_name41
dllabarre
Quote from: Jack Noskills on August 10, 2012, 09:32:24 AM
Maybe I was not clear enough but,
I have already solved this, coils connected so that output does not affect input and output power exceeds input power.
As long as you have primary that uses magnetic induction on secondary there is always magnetic induction back to source. Simplest solution is to separate the primary outside secondaries, two secondaries then feed each other. Do it my way, it is Don Smith for dummies sort of thing. Meaning power output is at Don Smith level, but making of the device is childs play. Just one rule, high impedance coil connected as shown in the thread. High impedance you then achieve with: frequency, permeability, number of turns or tuned cap.
Just one builder is needed to try it out, who's got the brass balls to do it ?
Jack
Please post schematic, parts list, wire size, number of turns for each coil, everything I need to replicate what you did with the exact same parts that you used.
Thank you
DonL
