0 Members and 18 Guests are viewing this topic.
cheappower2012
Hi all here's a little experiment that needs to be done
however we need to know the power rating of the transformer in the
2012 video.I normally do this kind of experiment however it uses parts I'm
not familiar with.
We need to try to figure out the path of the power from the transformer
to the black box.The reason for this ,is that if the origin is the black box then
it will be very hard to figure out since all working parts are hidden and
patients could be lies.If the power rating is less than could run the heater
then the origin point is the transformer.If the transformers power rating is
able to source the power,then its inconclusive.Its a 50/50 chance its the transformer.
This is the method I used on the tpu stuff,eliminate things,you can't simply build blindly
I have seen many people build blindly it ends in failure.
@stivep
do you know the rating of the transformer,since you posted a picture of a power supply
with a transformer like it.What the connections of the transformer are,are also important.
Do you know of a catalog to search for a match to this transformer.
Shokac
Quote from: wattsup on August 10, 2012, 06:41:26 PM
OK, so this last video was really nice but someone please transfer it to mpg or other format and post a link on where we can download it. My Youtube converter does not work and I would like to have a copy of that video "for closer looks" with VirtualDubMod.  hehehe
wattsup
Online converter
http://www.savevid.com/
x_name41
Quote from: cheappower2012 on August 11, 2012, 03:16:21 AM
not familiar with.
@stivep
No, be sure in this transformer is a low power!
cheappower2012
Your right x-name41 the transformer has to the correct one,I'm not an expert on these type of 3 phase
Russian transformers.I did find some US made small 3 phase
transformers,there bigger than the Russian one but could never power a 2kw load.
Also there very heavy ,another factor size and weight.A us transformer that could handle 2kw would weigh around 55 pounds,and is real big.If a exact match can not be found,we could find a slightly bigger transformer,the point eliminate things,if a slightly bigger Russian transformer can't power a 2kw load its game over.
This is size to handle a 2kw load,US
Weight 55.00 lbs. (24.94 kg)
LxWxH 9.00 x 6.00 x 6.75 in.
(22.86 x 15.24 x 17.15 cm)
