0 Members and 71 Guests are viewing this topic.
forest
Just measure core size (times 3 if 3 transformers in parallel) but I think it's no more then 500VA
a.king21
OK  Guys, apologies accepted: I have access to the best brains on the planet - an associate knows Tom Bearden and John Bedini. I am getting emails from Magnacoaster and KP's associates. I'm in the loop. OK?
1 TK's device is NOT UNIQUE.
2 Other FE devices are out there and can be seen.
3 Our interest in the TK device is because it seems CHEAPER to make. Do you get it?
4 If an FE device is expensive, then it is uneconomical. Simple as that.
5 Solar panels are FE.  If the price drops to 10% of what it is then TK has NOTHING.
ie If you can spend 500 dollars and get 10 KW worth of solar panels, then TK's device is worthless.
6 We worked out that we had a window of approximately 3 years to make this work.
7 Within 3 years we figured that the E-cat would be available to the mass market.
Think about it:-  6 to 10 kw of continuous energy for 500 dollars.
8 That's why I call TK's advisers STUPID. They have a toy that everyone wants?  Rubbish.
It's value is diminishing day by day.
Go back and have a look at my circuit diagram. I show you how to hunt for resonance.
Our biggest breakthrough was in understanding TK's psychology.
He is terrified that people find his secret because it is simple.
Once we knew that -  we realised that his devices are smoke and mirrors.
However, we think that some of the equipment on view is used in his patent.
One of the output coils or maybe the green transformer is the RESONATED.
If you look at my circuit diagram it is the one with arrows above it.
That means it is getting energy from OUTSIDE the system.
So there are two essential elements in the build.
1 the RESONATOR
2 the RESONATED.
It is not- repeat not- conventional Electro magnetic theory.
It is either ferroresonance or stochastic resonance or a new type.
We also worked out that he is not clever enough to make a H-bridge.
Certainly not in 1996
The RESONATOR is a FREQUENCY GENERATOR.
The RESONATED is a COIL -  maybe pancake, maybe bifilar wound.
So you wind various coil configurations as per the patent. You apply a frequency generator
and you hunt for FE. There are thousands of combinations of square wave, sine wave, and  other waves
at thousands of frequencies and many different windings.
The good news is that there will also be hundreds of harmonics.
The first person to succeed - pm me - we'll do a deal.
We can now FOCUS our research. We now KNOW where we have to look.
That is the BIG BIG difference.
frantz
Xname41 and cheappower2012,
As I wrote, we should focus on invisible part of device. Everything what we see is a scrap. TK showing only what he want to show. He is a showman as somebody wrote on this forum. I think he found something based on regular parts. Nothing special.
verpies
Quote from: a.king21 on August 11, 2012, 09:33:29 AM
Solar panels are FE...
Not continuous, not all the time and not everwhere.
In additon to the $500, to achieve continuous 10kW, the solar panels would need 140 square meters of strong sunlight (think Palm Springs...) and  Solar Trackers as well as huge banks of batteries and inverters for the night. (...trackers and rechargeable batteries do not last long).
x_name41
Other reasonable suggestion is a which the could give that a the blue coil is a primary, based on this material!
