frantz
Quote from: a.king21 on August 11, 2012, 11:36:56 AM
Some closeups
Thanx a.king
lets watch, on there are two small coils (not capacitors bank).
I think there is a secret of FE.
I will try to draw some general scheme for all and we will see.
watch carefully bottom of device....
HV wires are going near of this two coils. In my opinion this two HV wires are connected to this coils... ;-)
I will draw something and you will see why.
x_name41
Maybe like this?, cause in the me association with a L/C - parallel resonance, unilateral inductive coupling or source of power magnetic field in combination with 220v/50hz from green transformer?
wattsup
Quote from: Shokac on August 11, 2012, 03:21:48 AM
Online converter
http://www.savevid.com/
Thanks for the link but when you put that up, I though about it. I always use Naevius YouTube Converter 2.7
http://www.naevius.com/youtube_converter.htm
But, I was getting a ULR error when trying to download the video.
The ULR for that video when looking at in in the browser is...
https://www.youtube.com/watch?v=-4L0w56pa60&list
So in my converter I removed the "s" from the "https" and now it worked fine so I have my own copy now.
Funny though that in the browser when you remove the s it reverts back to the https default for that video location. Seems like it is on a secure server or something like that.
@all
I don't buy the spark gap being a loud limiter or overload protection for the load. First of all at no load the spark should have risen and it did not, and at load, the spark should have died down considerably as it would have played a power regulating role. None of that happened and the spark gap stayed the same.
But hey, guys should follow their instincts and lead them where it may. I just prefer to have some logical observational basis that is cohesive throughout all the devices TK built.
The fact is if ether is at play here for the OU aspect, you want to create a coil that when pulsed will attract more ether to the vicinity then one would expect otherwise under that same energy consuming means. The fat 6 turn outer coil is NOT a heating element. It is in series with the spark gap to generate or delimit the major field, like calling in the troops for action. This concentrates field presence in the center of the fat coil where you have the more densely wound TK coils that are inter-related or wound in half mode. Again why in half mode? Because that's all you need since the other half is coming from ground. Otherwise explain to me why you wind one long coil and another at nearly half or third length over it.
All TK is generating or transforming is his high voltage pulses into two paralleled outputs (to increase HV amperage) of positive potential and the ground if giving him the negative potential, because ground will give you all you need which is much more then what the system in its internal function can produce as negative potential. Alone the system produces a strong positive but weak negative so instead he takes the strong limitless negative from ground.
The frequency required is not important to make the spark gap function because the SG can work in a wide frequency range. The frequency is required to match the resonance of the TK coil as this is where the coil can receive and output at the highest and most efficient level.
But again, all may have their views on that function and I respect them all but my experiments will verify these with time. hehe
wattsup
PS: The previous post from @Collapsingfield of attached pdf explains this better. So imagine you have a high voltage negative available at all times. Where you see the ground loops, those can be easily present in the TK coil. Now matching that with a positive HV of high enough amperage is all that is required to light them bulbs.
Hoppy
Quote from: Collapsingfield on August 11, 2012, 10:45:41 AM
This document looks interesting considering the length of the ground cables at TK. His ground is not a ground at HF. After reading you will understand this little idea: look the rate of the length of the cable in coil to the length of the ground cable. The coil is not a coil, just a cable, like virtual ground. The bifilar winding reduce its inductivity. Calculating the lengths can help to find the frequency. Remember, TK started with two grounds.
Collapsingfield
So given a long earth cable and series HF transformer (the blue coil) open ended, a nearby and powerful RF transmitter ground lead hooked to TK's ground point (a conductor within the earth lead braiding) - that was not actually grounded at this point - could induce plenty of power into the 'earth' line as a standing wave, which in turn could be processed to power the electric fire in pulses? The actual ground being returned through the braid of the TK cable under the control of the protective spark gap??
Hoppy
