0 Members and 98 Guests are viewing this topic.
x_name41
To tell truth in some experiments with my Tesla transformer is which was held long ago i noticed that the power conductor is not heated when is connected to a ground, while in the absence of ground heating was significantly!
Free.Energy
Why is the large circuit board in the clear box painted black?  Looks like it came from industrial equipment.  One side if this board has outlets for electric plugs like it may be an inverter.  What if the black box has a battery to start the energy?
Kapanadze may not be able to make an H-bridge, but he may be able to find a motor driver that has H-bridge.   Sure Kapanadze can build a multivibrator and the green box device had two transistors on top.
a.king21
Quote from: wattsup on August 11, 2012, 12:53:57 PM
Thanks for the link but when you put that up, I though about it. I always use Naevius YouTube Converter 2.7
http://www.naevius.com/youtube_converter.htm
But, I was getting a ULR error when trying to download the video.
The ULR for that video when looking at in in the browser is...
https://www.youtube.com/watch?v=-4L0w56pa60&list
So in my converter I removed the "s" from the "https" and now it worked fine so I have my own copy now.
Funny though that in the browser when you remove the s it reverts back to the https default for that video location. Seems like it is on a secure server or something like that.
@all
I don't buy the spark gap being a loud limiter or overload protection for the load. First of all at no load the spark should have risen and it did not, and at load, the spark should have died down considerably as it would have played a power regulating role. None of that happened and the spark gap stayed the same.
But hey, guys should follow their instincts and lead them where it may. I just prefer to have some logical observational basis that is cohesive throughout all the devices TK built.
The fact is if ether is at play here for the OU aspect, you want to create a coil that when pulsed will attract more ether to the vicinity then one would expect otherwise under that same energy consuming means. The fat 6 turn outer coil is NOT a heating element. It is in series with the spark gap to generate or delimit the major field, like calling in the troops for action. This concentrates field presence in the center of the fat coil where you have the more densely wound TK coils that are inter-related or wound in half mode. Again why in half mode? Because that's all you need since the other half is coming from ground. Otherwise explain to me why you wind one long coil and another at nearly half or third length over it.
All TK is generating or transforming is his high voltage pulses into two paralleled outputs (to increase HV amperage) of positive potential and the ground if giving him the negative potential, because ground will give you all you need which is much more then what the system in its internal function can produce as negative potential. Alone the system produces a strong positive but weak negative so instead he takes the strong limitless negative from ground.
The frequency required is not important to make the spark gap function because the SG can work in a wide frequency range. The frequency is required to match the resonance of the TK coil as this is where the coil can receive and output at the highest and most efficient level.
But again, all may have their views on that function and I respect them all but my experiments will verify these with time. hehe
wattsup
PS: The previous post from @Collapsingfield of attached pdf explains this better. So imagine you have a high voltage negative available at all times. Where you see the ground loops, those can be easily present in the TK coil. Now matching that with a positive HV of high enough amperage is all that is required to light them bulbs.
Ok - replicate it and pm me. We'll do a deal. We have two factories waiting.
a.king21
Ground wire: On one forum the ground wire was found to keep the device in phase. I guess it  prevents capacitative build up. In one of my experiments the ground wire doubled the power in my experiment. So it is important, but can also be replaced with the neg terminal of a car battery or a long wire. My conclusion is that it produces a standing wave, which can double your power also under certain circumstances. Oliver Lodge found out about standing waves in the 19th century. Tesla discovered that lightning also produced standing waves which appeared to replicate  the lightning discharge  after a few seconds.
T-1000
Hello,
I am going to ask a bit off topic question so please ignore it if thats spamming your screen ;)
I have trouble with identifying ancient language/code used in following picture, maybe you guys seen seomething like one in picture attached. Please let me know if you are able to identify/decode message:
