0 Members and 137 Guests are viewing this topic.
forest
Quote from: Free.Energy on August 12, 2012, 03:23:33 PM
An alternate opinion:
2004 video was early prototype and nothing is hidden.
There is no means for overunity in an ordinary transformer.
TK method for driving TK coil is secret.  If you find translation of green box video in pdf from years ago TK says resonator is in the box and is secret.  TK also says he found way for primary to always resonate with secondary and he names this autoresonance.  This is not electromagnetic resonance or even a resonance at all.  I attach this file.
The measurements are not successful since current is longitudinal else power flow to earth will not work.  Clamp meter does not measure longitudinal current with electric field parallel with wire.  This is where the answer will find.
The ether cares because electric field modifies ether but only with rapid change.  The repetition rate is what TK confuses with resonance.
See in all TK coils that the cable to ground is inside the coil.  Why is this?
We are far from the trash and expect full success in 2012.
Can anyone here build low frequency high voltage pulser with variable frequency?  Am I solo?
Use two CD4047  ;)
verpies
Quote from: frantz on August 12, 2012, 12:49:20 PM
As somebody wrote previously, this transfotmer can operate on 500W totally.
Question is where is rest of the power...:-(
That's true for 50Hz only.
For higher frequency much smaller transformer would suffice.
For example consider the ATX Computer power supply.  It can transform voltage and current at 1.2kW power levels in the small and lightweight ATX or BTX enclosure ...using light high frequency transformers
frantz
Quote from: verpies on August 12, 2012, 03:44:51 PM
For example conisder the ATX Computer power supply.  It can transform voltage and current at 1.2kW power levels in the small and lightweight ATX or BTX enclosure ...using light high frequency transformers
we are talking about ordinary transformer with iron core (like green one in TK2), I hope, not about pulse power supply with ferrite cores.
verpies
Quote from: a.king21 on August 12, 2012, 02:39:35 PM
Here's what I think:
Kapandze's secret = transformer with 3 coils
Coil1 powered by function generator = RESONATOR
The successful Yoke device discussed from page 550 to page 700 of this thread, also had 3 coils powered by function generators.
