0 Members and 313 Guests are viewing this topic.
grizli
Quote from: Omnibus on April 02, 2010, 11:10:20 PM
Here's the suggestion of a member with a handle @Wille Brauh in: http://www.001-lab.com/001lab/index.php?PHPSESSID=52718a50696b58022961d496982fea85&topic=4.1000
hmm
I wonder if here are actually BJT, not mosfets ?
one of mosfets HAS to be on gnd , other has to have ferrite driver of source is not on gnd
or he can have both mosfets at gnd but primary of transformer has to be dual (push pull)
S and G connected together has NO sense for sure this are bjt
xenomorphlabs
Quote from: grizli on April 03, 2010, 06:28:22 AM
hmm
QuoteThere is using PNP and NPN bipolar transistors, each on their half-wave.
@h2commuter:
I listed that patent number,i have read it before and there is no mention of a spark gap running at 50 Hz, i am sorry but there isn´t ;)
It would be valuable to actually find that stated in a patent (less speculation then), that´s why i was interested in knowing about it.
Since you mention the word comparator, there is no such word in the patent, so you might have given the wrong link.
BUT while reading through it again (and again and again hehe)
i stumbled upon the words :
Quote4- High frequency generator
5- First filter
So this could either indicate the PWM sine inverter where with the filter the high frequencies are being filtered out.
Or we still have to consider the use of high frequency signals (at least in the device talked about in the patent)
Here is a russian interpretation of SR´s circuit.
The spark gap seems to feed that thin wire that maybe just runs under the thick wire along the coil former to ground (as visible in the video)
The signal generator part is still a bit unsubstantiated.
Actually as this schematic is right now, this looks like a standard sine inverter 12 V to 220 V with the only difference that a high voltage pulse
is being run through the coil via the spark gap and that the blue coil winding differs.
grizli
so what is the effect here
affecting ferrite with HV low current low power , so it can be magnetised? hmm
schematics is no problem just effect has to be understood..
grizli
QuoteSo ...
Ð'НИМАНИЕ !!!!! WARNING !!!!!
ЭлекÑ,роэнергия у меня бесплаÑ,ная и смысла пиÑ,аÑ,ься оÑ, эÑ,ой усÑ,ановки я не вижу и поÑ...оже она вредна за счеÑ, своиÑ... излучений два дня с ней рабоÑ,ал и два дня у меня повышенная Ñ,емпераÑ,ура и головная боль..... Electricity me free and make sense to eat from this plant I do not see and it looks like it is harmful due to its emissions for two days with her and worked for two days I had a fever and a headache .....
hmm
can it affect human bio energy hmm
BB had cancer, Sweet had cancer ... hmm
Omnibus
Quote from: grizli on April 03, 2010, 09:37:08 AM
hmm
Who said that?
