0 Members and 74 Guests are viewing this topic.
@hoppy: I guess it depends on what is meant by "put forward".
Go outside TK's house during a demo and pull the main breaker. That is one experiment I'd really like to see. With the information gathered from the results of that experiment... or its attempt.... speculation could be more informed.
v8karlo
Quote from: 27Bubba on August 17, 2012, 08:35:50 AM
@V8Karlo
Yes, I see you are using the IRF840 Mosfet witch does have 3 legs, but in your drawing  I don't see that. How it is connected? Thanks.
I didnt draw the signal leg, just source and drain (plus and minus side).
One thing about mosfets. If the signal gen. isnt from the same
power source as your power source for the coil it wont work properly.
In that case you must connect minus from your power source of your
signal gen. to minus of your power source for your coils, assuming that
they operate at same voltage.
It must close circuit through its source leg and gate leg to open and close.
If you have connection to your mosfet only through gate and your power source
for coils is from battery which is not connected to anything it wont open and
close properly.
stprue
@v8karlo
Can you provide a full crt diagram with all connections so that there can be no confusion?  This will make for much quicker replications to verify your claims.
Hoppy
Quote from: TinselKoala on August 17, 2012, 10:24:51 AM
@TinselKoala,
Yes, I should have said, apart from the explanation put forward that it was faked. I can't see TK now allowing a serious team of investigators anywhere near the house, let alone his device.
Hoppy
v8karlo
Quote from: starcruiser on August 17, 2012, 10:07:05 AM
The spark gap in this setup is for demo purposes only as this is on the output of his trafo setup. In all cases I am thinking the SG is for over voltage protection and not part of the power generation, at least in this situation.
I am getting ready to try a few experiements myself, just finishing up my secondarys for my Tesla coils then I can focus on the cap coil idea, going to try air core first then try with a ferritte core. Now what would happen if one would cascade 2 such units? what would the output be?
This setup reminds me of the SM TPU large center core torrids, I wonder if this was the secret, input caps (yellow), 555 timer circuits for driver and a second air core coil for amplification, just thoughts... something to try I suppose.
I did cascade two of them. At the end of first put fat electrolyte cap 220uF, 400V , then second mosfet
just like in first one. Problem is if your second circuit stop operating, you have 10-15 second before
220uF, 400V rupture.
The results at output were same as when I use only one device but paralleled 2 Power sources
from PC supply , 2x12V = 24V with same 250mA. Result were almost identical in that two cases.
Without load 1,4A, and I didnt try to gain voltages over 1200V. So , my conclusion for that
case was that there is positive amplification and that capacitive coils are more powerfull than
inductive.
When 220uF, 400V rupture there is loud bang, after that didnt go further in that direction.
