0 Members and 322 Guests are viewing this topic.
semenihin-77
Mathematics for Kapanadze:
Of 220 volts through a step-down transformer get 12 volt 3 ​​amp, which translated in watts - 36 watts.
Take the reference voltage 220 ​​volts, and add these 3 amps, we output 660 watts.
Unfortunately I found the inverter transformer output.
Use a step-down transformer to the output 40 volts, as the reference voltage.
http://www.youtube.com/watch?v=hW_KNKVC-DE
forest
Quote from: Jack Noskills on August 23, 2012, 02:56:36 AM
You make LC circuit that has only R to slow things down. If R is zero it runs forever, remember Tesla experiment with cooled down wire that run for three years. Each cycle is copied to secondary, if no load then LC circuit keeps on running forever. The instant you connect your secondary to load there will be back EMF that opposes LC circuit, resonance is destroyed. Now source sees this and pushes more and power gets used. But if you take this power from secondary so that resonance is not destroyed, your primary LC circuit still runs forever and what ever power this source has circulating you can freely take. Very simple to understand yes ? TK figured this out, so did v8karlo and so did I. Just crank up the frequency and power circulating in the source and energy abundancy is yours, just like Don Smith has said.
This is the most important comment ! Yes, you are right but we need to find every possible method of not disturbing resonance. I don't know why delamorto is not commenting this  :o One way is to mix high frequency with low frequency wave correctly at peaks of magnetic field. You have got now two powers at two frequencies , when used correctly you can use lower , filter out higher store and feedback to almost run device on itself.
That proves magnetic field can be freely available in circuit with resonance maintained or like you described with closed loop circle without resistance. Next thing is the way to eliminate magnetic resistance or drag and here we should put much more attention because it seems that correct (I would call it "sacred") form of device would allow that.Expect a delay or inertia after disconnecting device, only cause by ohmic resistance....
leo48
Hi Bernhard
if it is possible to obtain the measurement of the iron core of the transformer X and Y in this snapshot?
Thanks
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
Jack Noskills
I made instructions how to make high frequency device that uses capacitive induction, effect I accidentially stumped into six weeks ago. Did not know it had a name. You can find step-by-step instructions below:
http://www.overunity.com/12487/simple-to-build-isolation-transformer-that-consumes-less-power-than-it-gives-out/msg333308/#msg333308
If you have stuff laying around, then it is time for some experiments and sharing. Don't spend any money for new equipment, use what you have. Only thing you should do is to perform some tests if you got the gear. This is a low budget device, not a Tokamak.
Easy build and test procedure, sooner it fails then sooner you can stop working on it. If some stage fails, then tell about it but prepare to be precise in explanation so problem can be solved if it is solvable. Remember that no result is also a result.
Oh, and it explains also how to get free energy from a CD as a bonus ;-)
Hoppy
Quote from: a.king21 on August 22, 2012, 08:09:04 PM
I was not going to take his post seriously and neither should anyone else. Yes there is a wire there, just as in your house there are many wires. Mobile phone chargers, battery chargers, electric radios, tvs - need I go on? The device was scrutinised by all present and a video taken. The silver braid was tied in a rough knot to a bronze braid.  Grow up Hoppy. Get a life.
Then why take the cable through the chair legs so that when the chair is moved it fouls / pulls the cable.
Like others, having experimented in the FE field for many years, I would dearly like this device to be proved genuine but with this cable appearing to run into the earth cable it does look very suspicious, especially when on the wall behind the chair, there appears to be a power point? You mention TK not wanting to conduct the demo until the storm ended. He may have been more concerned that his own domestic mains supply would get interrupted during the storm!
