verpies
Quote from: Zeitmaschine on August 29, 2012, 08:50:33 PM
Received by what? The blue coil? Because ...
The blue coil/transformer would not be the best choice for near-field power transfer due to its low cross-sectional area (...however it would be a good choice for kHz switching voltage converter/regulator).
I think Tinsel's idea about the aquarium's frame functioning as a receiver coil is the best choice, becaue it has large area and its 3D geometry makes it insensitive to XYZ rotation.
Quote from: TinselKoala on August 29, 2012, 08:39:05 PM
The metal frame of the aquarium would probably be a good match...
Something with the physics is very wrong here. :(
For the sake of humanity - I sincerely hope so.
verpies
Quote from: a.king21 on August 29, 2012, 09:05:06 PM
Kapandze would probably build you a device for that sum. If you're serious I'll put it to him.
(To look at, I mean, not to take away lol.........)
Don't contact him on my behalf because most likely he is hostile to you (and anyone you recommend) for objecting to being ripped-off for $20k and instituting legal action against him. (which I think you have the full right to)
It is obvious to me that TK does not want us to see what is inside his aquarium (it's a "black box" for all intents and purposes).
However, I would gladly invest $1000 to credibly inspect/measure outside of this box, such as:
1) the size of the "black box"
2) the weight of the "black box"
3) the external interfaces of the "black box":
    a) any conductors protruding outside of of the "black box", e.g. wires, braids.
    b) near-fields that could be used for wireless power transfer, e.g. see: http://www.youtube.com/watch?v=kulGKroR0yA
4) the power delivered to a resistive load (e.g.: light bulbs or a space heater)
    a) using this photodetector method: http://jnaudin.free.fr/kapagen/kapagen33pio.htm
    b) observing power delivery during the time that would indicate clear (200%) superiority of the "black box's" energy density compared to the best batteries avaialable today. Energy density of the "black box" would be calculated from measurements made in pt.1 and pt.2 and pt.4a multiplied by the duration of the observation.
P.S.
Optionally, I very much would like to cut and then resolder the conductors mentioned in pt.3a.
verpies
Quote from: Hoppy on August 30, 2012, 02:36:46 AM
   What about mains failures? No Free Energy during a blackout would be somewhat embarrassing, wouldn't it?
Indeed, that's why TK may have been concerned to do the demo during the storm. However, the battery would probably be able to cope with 'brown-outs'.
That's the best explanation for TK trepidations about the storm, that I have read so far.
Storms are not solely responsible for power outages, for example...
captainkt
@Hoppy, why the fascination with braid and power feed through it? After all where is braid in green box, Island vid ,Booth vid or other 10 Kapanadze devices. They all obviously have a common (secret if you like) but braid is in full view so this would not be it. The braid if anything is acting as a capacitor and nothing more. I ran 2.5 KW through coax only lasted few minutes then heated up to dead short. DOES NOT MATTER IF LIVE OR NEUTRAL SAME LOAD/AMPS IN EITHER.
Keith
Hoppy
Quote from: verpies on August 30, 2012, 04:50:27 AM
P.S.
Without a proper investigation as detailed by Verpies, it would IMO be pointless to continue speculation on the modus-operandi of the device. Clearly, if it can be established conclusively that the device is not powered from an external source, then and only then should any serious financial investment be considered.
Signing-off for the time being.
Hoppy
