0 Members and 234 Guests are viewing this topic.
verpies
Quote from: Osiakosia on August 31, 2012, 04:43:26 PM
Hello Verpies ,
I just have finished my 2 Mhz power amplifier on the PA107DP chip .
This is why I did not have any new results regarding yoke device .
You are right . It is difficult to tune this device . Few times I have atchieved the sinus wave signals on the 50 turns coil but  did not understood the couses from which its depends ( from strenght of  generator output or the dimension  of U-shape turn) .
The PA107DP is a good amplifier but it's way too expenive.  I feel guilty for having it mentioned to you.
If you followed its documentation, then you Signal Generator should be well protected and its signal strengthed significantly.
What did you use for the ~100V power supply ?
Regarding the tuning, I recommend asking for help the people that  were sucessful with it at least once.  I think they are not like Tariel Kapanadze and are willing to guide you.  It may also help you to read and watch all of the links in Slapper's Reply #13247 and remember that for NMR you need to excite the core in at least 2 dimensions (corewise).
From myself I can add, that a wide and thick copper foil is essential for the U-shaped turn in the Yoke Device.
A copper braid is unsuitable.  Thin or aluminum foil might be a mistake, too.
T-1000
Quote from: verpies on August 31, 2012, 06:54:31 PM
For NMR - first of all you need to imagine entire picture in 3D how each little compass needle (atom spin) can be rotated when you introduce two magnetic signals on 90 degrees to each other. Then you need to keep one signal as current for driving transformer action and second on making core's atoms spin to dealign from main polarization on their natural resonant oscillating frequency.
Only after this http://www.youtube.com/watch?v=W-c5zSviuXk and http://www.youtube.com/watch?v=h611QzPsDQI process will be much more clear how to apply in your specific situation with your yoke or other core based transformer with two primary coils and third on tank circuit(90 degrees copper strip with capacitor) or similar setup magnetic fields vectors crossing core in 3D and doing reonant magnetic oscillation.
Then go back to http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg303720/#msg303720 and read my posts all over again (sorry for picture links to website there, it gone down).
Also here is same energy extraction from NMR effect described in patents:
http://www.nuenergy.org/pdf/GB763062.pdf
http://www.rexresearch.com/meyernmr/meyer.htm
Cheers!
yfree
Quote from: verpies on August 30, 2012, 04:50:27 AM
It is obvious to me that TK does not want us to see what is inside his aquarium (it's a "black box" for all intents and purposes).
I would go even further. Inside the Aquarium there is a black box (no quotes). In every demonstration of TK, there is always a box that is sealed and not accessible to onlookers.
By now, I am sure that TK's  conversion devices are not the ones that are visible and recognizable in his demonstrations.
I would start from ...  the coil; it has as many shapes and sizes as the number of demonstrations he released to the public. This last blue coil (Aquarium 2), terrace wound, with the stiff wire doughnut shaped coil at one end was simply too much, too cheesy. My view has changed dramatically; "TK's coil" is no longer "the coil".  The exposed coil, "adored" and debated on endless pages of discussion forums is just a coil and serves a purpose of a coil and not the purpose of energy conversion.  The secret is always hidden in a box.
Please review the videos; starting from the tin can, through the "green box", through aquariums...
Count the number of sizable square boxes in the Turkey videos, both the one with huge sparks and the recent ones. How many sealed boxes are  visible in this photo?
wattsup
@Zeitmaschine
Thanks for posting the other option I had mentioned in my last post. Yes, this is #2 way.
The connection from output to ground is either of these two possibilities but I am convinced it is 1.
1) HV+ (C) -> Load -> TKc -> Ground Wire (or)
2) HV+ (C) -> TKc -> Load -> Ground Wire.
Unquote
Although the HV- going to that transistor is not correct because there is no wire to support it and that HV- does not need a transistor.
There are two possibilities with the wires as seen.
Also in the post I indicated that the coax is open ended on the HV+ side but could be shorted to the center conductor HV+ before going to load. This works either way.
So imagine the HV+ is going inside the coax, the effect on the shield wire will be great and all positive heading for load. This you did not take into account on the amperage ability. But at least we are talking the same language.
About cancellation, I don't think so because the shielding will be energized so the center conductor will not even see the other layer conductors. It is like this wire was straight or coiled, will not make any difference and will not cancel out. The only thing it can do all coiled up in a TKc is produce a more condensed mass effect for more ether to pile on the shielding and increase amperage. This is the only way possible for this to work as you mentioned, by themselves they cannot and you are right about that.
Either way, the triple transformer connection and usages that I mentioned could still apply. Also your wind ratios are the same as mine, turn quantity is irrelevant if you stick to the ratios.
Thanks for making the diagram. Really nice work.
@stivep
I just purchased that 1000 foot roll of triax cable but am in Canada. Well not the first roll. I bid $100 and a guy beat me in the last 5 seconds at $102.50 (imagine). But there was a second one. This time I put 100$ and put a max bid of $120, but at 25 seconds I got this bad feeling and increased my max bid to $140. I got it at $132.50 so his max bid was $130 and I won. This cable is selling for $2 a foot.
I am wondering if I can have that spool shipped to you in NYC and ask if you could cut me two 200' lengths and send me the two lengths, use the rest yourself as a gift and send some to anyone else that will build and test. If this is OK, could you please PM me your address and I will ask the seller to ship it to you. But either way, please let me know if you can or not. hehehe
But I am winding a regular coax this weekend and put it on my bencheroni. Can't wait to test with or without shield shorting to center conductor.
wattsup
wattsup
Quote from: yfree on August 31, 2012, 09:28:23 PM
In that photo of that demo, consider there is one real Tesla coil producing HV+ and all those other towers are TKc's that are then paralleled into three phase. I counted one Tesla coil plus 8 towers that I could easily see but there could be 9 towers, paralleled in threes then feeding the three phases.
TK has no choice but to always hide something. It could be the most mundane things to hide, but you and I will always be asking questions. His secret could be totally in plain view.
Story.....
A guy works in a gold mine for 35 years and everyday he brings out a wheel barrel full of earth through the front gates, where one of the guards checks the contents of the earth to see if he is stealing some gold. But every day, the guard finds nothing. When the worker retires a few years later, he meets the guard in a pub and they start having a few bears. After a while the guard asks the worker off record, "How did you steal the gold? Where did you hide it?". The worker says, "I never stole any gold. It was the wheel barrels I took." hehehe
So sometimes what is in plain sight could be the secret but since he always had a black box, this is enough to keep you on edge for ages. Imagine if you saw the complete device, an experienced guy would be able to pin point any and all possible functions so fast. So TK keeps some stuff in a box thinking this will keep their secret. The box is never big enough to harbor any serious batteries so his point is made load and clear for the demo buyers and he is free to continue without anyone finding his secret. hehehe
If it is a trick, it is a damn good one.
wattsup
