Zeitmaschine
Quote from: yfree on September 02, 2012, 07:03:32 PM
No, we are not back in square one. Not everything is fake. Watching the available videos carefully and applying logic and physics, we can get very far.
Very far at least in page numbers of this thread. ::)
And is there not the saying don't apply logic and physics to the TK device?
Hence, what could happen if a high voltage (high frequency) spark hits not a coil or the windings of a transformer but the iron core of a transformer itself, or it hits the aluminum housing of a large capacitor? This illogical idea (that will surely never work) just crossed my mind.
So maybe we are back to square two.
a.king21
Something to consider: The output spark gap is HV. The wires to the Spark plugs are HV. The wires to the heater are HV.
The braid is a HF/HV shield.
Conclusion: His secret somehow generates HV, whilst using mains 50 Hz 220 volts.
The centre of his blue output coil pack is shielded with what appears to be polystyrene.
He also uses transparent polythene sheeting all over the place. Also He shields HF/HV by the judicious use of Plexiglas.
He even has the spark gaps mounted on HV shielding (Plexiglas).
Importantly:He does NOT shield the earth braid.
This explains why his builds are light.
Suggestion: Do the experiments.
PS He's also an expert in 3 phase.
I suggest we look at where shielding is used (defence mechanism)  and where shielding is deliberately not used - but conventional physics or electrical installation statute says it should. - Across ALL his builds, including Wesley and 2004.
a.king21
Quote from: Zeitmaschine on September 02, 2012, 07:30:16 PM
Done the experiment. lol
You get resonance between L1 and L2.
a.king21
Quote from: verpies on September 02, 2012, 05:30:55 PM
Neither do I.
9A going through a 70Ω winding would dissipate 5670W in it
9A going through a 0.5Ω winding would dissipate 40W in it, so that's a little more plausible.
9A going through the core metal itself is even more plausible.
If the voltage supplied to the heater is much higher than 230V then the current would be proportionally smaller than 9A for the same power level, but that trick would require a step-down transformer (or inductive buck converter) INSIDE the heater.
isn't a hidden/invisible wire an another possibility on that video?
Relying on theory doesn't work.  History has proved that a lot of theories are ultimately wrong. They become superceded by better theories.
I have an advanced level physics book. In it the author is talking about one experiment. He states," This is one of the few experiments that agrees with the theory"  You should all read that quote again and again and commit it to memory as I have done.
Another way of stating the same thing is to say, "Most of the theory in this Advanced level Physics book is bollocks in 2012. Eventually our descendants will figure it out. But first they have to realise that I am getting paid for teaching bollocks. Which in any other profession would be called fraud."
The only answer is to do the experiment.
a.king21
Notice the braid is suddenly shielded. Because it HAS TO BE  - at that point. We're  getting closer Mr K.
Also maybe Zeitmaschine can see something clearer on the empty pin.
