0 Members and 135 Guests are viewing this topic.
baroutologos
@Xeno,
In Teofilius fake video I had a youtube responce from SR admin. Then we communicated in youtube email and he told me that he gonna close down his youtube accounts and stimulated me to communicate via his forum admin e-mail.
Since he put up his own video replication he has not reply to any of my requests.
My initial impression is that he is a clever guy. And he has fully realized that he has not revealed anything specific except the hint that he uses ferrite cores, a HV source and an inverter setup. I believe he is fully aware of the situation, of our desire to have an OU device and replicate it and our frustration to understand how his device is supposed to work with so few clues. Even Sherloc Holmes of electronics could not assemble that i guess..
After my few ferrite experiments I tend to think better to invent your own OU device rather replicate SR's :) (joke intended)
hartiberlin
Hi baroutologos,
you always use series resonance LC circuit as the output.
WHy don´t you use parallel LC output circuit and have L and C and the
bulbs all in parallel and remove the variable choke and better use
different capacitors to get to the resonance.
ALso please use a ground wire to the lower side of the bulb and see,
if this helps.
Then see, what the resonance frequency is of this parallel LCR
tank circuit and use the exact same pulse frequency at your spark gap
by using an additional feedback coil which triggers the spark gap
with a small electronic circuit that adds to the breakthrough sparkgap voltage,
so the sparkgap is triggered at the same frequency as the LCR parallel
circuit is resonating.
You loose too much power in the variable choke in your setup...
and you don´t collect the free electrons from the ground...
Regards, Stefan.
hartiberlin
Hi baroutologos,
you also have to watch thee Q factor of your LCR circuit.
Just the LC circuit should always have a very high Q factor, so
it is ringing already. So you need to match the capacitance and the
inductance of this LC circuit for maximum Q factor.
When the bulbs as the load R are then in parallel to the LC circuit,
your Q factor goes down, but without the load R bulbs, the Q factor
should be very high and don´t forget the ground wire to attract free electrons.
Regards, Stefan.
baroutologos
I am aware Admin about the Q . This LC as i see it is, it's not a purpose of its own.
It is supposed to enhance the power generated for the R consumption. This does not happen.
regarding ground: Also i have been experimenting with a grounded wire touching it all over the circuit. Marginal lamp brightness increase is observed. Too faint to be captured by the photograph.
regardings variable inductor: This 1cm diam AM radio core is suitable to work under those conditions (68Khz) namely without losses because current circulating (as bulbs show) does not overcome much the 1amp. By the way the usage of 2 cores (see previous post) does not increase performance at all. Cores stay cold all time. Nevertheless, i stay with this approach as it is quite analog whereas i have not a huge range of capacitors to match the resonance otherwise.
parallel vs series: I have done it in the sence i put the lamps in parallel to capacitor. The lamps approach the brightness as if the capacitor is absent.
But apart from this relative low Q setup, I have conducted experiments with my large Tesla coil , or Magnifier as i call it (coreless of course) that has quite large Q value and works at about 170Khz. Cannot spot any hint of OU there.
ps: I know if i make all the talking about the LC resonance and its potential is frustrating (and there is the possibility to be wrong). So at least few other individuals are needed with different setups just to crosscheck observations.
baroutologos
In case we talk about ground usage. Perhaps should step someone knowledgeable to explain us in simple terms what exactly the ground is supposed to do and how heavy amperage is said to be observed in those devices...
I have not a clue  ??? The only ground usage i can make with some serious amperage is in my Tesla coil setup (small capacitance that is charged to enormously voltage and HF) or if i connect a lamp to a mains "hot wire" and the other pole to the ground (radiator) thus cheating people.
