0 Members and 165 Guests are viewing this topic.
jbignes5
Quote from: Zeitmaschine on September 22, 2012, 08:30:21 AM
Since I'm usually a little bit slow on the uptake, has this something to do with the bank of capacitors seen in the yellow tent presentation?
Below the first image shows a bank of high voltage (one-phase) capacitors connected to some 50Hz microwave oven transformers. Allegedly the result is, that the consumed current of those transformers goes down from 180 to 100 amps, as stated in the video.
The second image shows a bank of three-phase capacitors connected to a Kapanadze device running a huge three-phase motor.
Now the question arises: Are these capacitors in the TK tent presentation necessary in order to compensate the induction of the huge three-phase motor? If so, then why they are obviously still/already connected in this video without the motor (third image)?
TK takes measurements on the heating elements hence the device is running without motor (and without the slightest noise due to HV and/or HF), but I can't spot any difference in the wiring concerning the bank of capacitors (they are fixed wired without any plugs or switches).
Hence if the conclusion should be that these capacitors are not necessary in order to run the motor, then the only remaining conclusion can be that they are necessary in order to run the device. Got you TK. :D
So (since the huge coils are phony anyway) any ideas how to connect a capacitor of some sort to a 50Hz transformer of some sort in a way that the transformer provides more energy than it consumes?
How exactly did you figure out the huge coils are fake?
Lets figure out what TK was doing here. This I believe is only a demonstration of the Tesla wireless system. That is it. This is not an overunity device. It is merely a demonstration to a power company of how to use Tesal's system so that they did not have to invest billions in infrastructure like poles and wires. The wattage is only the maximum ability of the unit to transmit the power to their customers. I think this was taken out of context and Assumed it was a power production unit. Which it is not. So if we put all of these devices together you have power generation 2004 video, power transmission without cost of wiring (Turkey video) and power reception unit fish tank unit. I could be wrong about that but I don't think so.
Zeitmaschine
Quote from: jbignes5 on September 22, 2012, 09:12:55 AM
What I suspect is that TK read about Tesla's wireless system and saw a way to creat a capacitor of very large capacity.
And in doing so he discovered something completely different.
Then why the measurements in front of the camera on the input power cable?
Quote from: jbignes5 on September 22, 2012, 09:32:58 AM
First, because the three-phase motor runs on 50Hz, but a one-layer coil without core can't influence a 50Hz current significantly. Second, there is no helical coil anywhere near as seen on the 2004 device, thus it cannot be the same principle of work (even if there is a principle at all). Third, high frequency (from a hidden spark gap?) in these huge unshielded coils would pollute the whole environment with magnetic waves disturbing all kinds of electronics nearby (but this was not observed).
Now some calculations: The device in the tent presentation is allegedly rated at 100KW and it uses 12 big capacitors. That makes 8.33KW for each capacitor. The 2004 device runs with a load of 5KW, maybe it can supply slightly more. That suggests one of such a big-sized capacitor is needed for the 2004 device. Question: Where is this capacitor? Does it fit into the tin can? If not then the only capacitor that comes into question is the capacitor hidden behind the coil next to the transformer. But in my understanding this capacitor is a (polarized) filter capacitor connected to the DC of the diode bridge not directly to the transformer.
So what could be the signification of this? ??? ::) :)
sparks
    The ability of the electric field to accelerate electrons is a pretty wonderful thing.  The ability of the magnetic field to guide the electrons is just as wonderful.    Imagine an electron leaving a cold cathode due to a high voltage pulse.  The electron is acclerated by the electric field towards the anode.  It goes faster and faster and faster and smacks into the anode at 1/6 the speed of light.  The resulting collision releases large amounts of energy bound in the electron orbital momentum of the anode metal.   The anode metal is sprayed on top of a flurescent coating which coats the inside of a bottle.  The bottle has been evacuated so the electron has very little chance of slowing down in unwanted collisions as it is being accelerated by the electric field between the pulsed anode and the cold cathode attached to ground.  The electron collision in the anode metal results in the creation of energy far in excess of that needed to accelerate the electron.  This is especially true if the pulse is recycled in an electrical echo system.   The flurescent coating takes the created xrays and converts them into visible light.  The electron can also crash into a special pulsed anode and pop out a neutron.  The neutron then emits a new electron and very high frequency photon in the gamma ray spectrum.   These crazy neutrons take 12 seconds to become a proton.  Once you have a proton it stays a proton no matter what you do to it.  Funny thing about protons is that when they are accelerated or deaccerated they need to shed their rest inertia by creating photons.  Somehow these particles defy Einsteins theory that electromagnetic radiation is the transfer of inertia.  We can take a proton and accelerate it in an electric field or deaccelerate it in a magnetic field and yet there is no radiation, or is there?  Perhaps the radiation is of such a high frequency or low frequency that it gives rise to the gravitational phenomenon?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
stivep
Please revisit and re-read, article at page 940
Reply #14097 on:Today at 09:04:18 AM »
I have made major  additions and corrections to it
Please concentrate on electrostatic resonance
Wesley
verpies
Quote from: sparks on September 22, 2012, 11:19:56 AM
Why?
