0 Members and 51 Guests are viewing this topic.
a.king21
Re Bifilar coils. At one time I was having an intelligent conversation with Kapanadze and asked him about the possibility of miniaturising his device. We discussed the possibility of having a self powered vacuum cleaner. He said that it posed no problem to his device, and the earth wire could be replaced with a circuit, namely the negative terminal of a small lead acid battery. (That is pure Tesla, anyway). I asked him if it was possible to have a self powered table lamp: He said no problem. Self powered heater?: no problem.
I then asked him if it was possible to micro-miniaturise his device  inside a CFL lightbulb. He thought for a while and then said it would be impossible because of the coil windings. He said I may have noticed that his coil windings were bifilar, and that he felt  he could not miniaturise these to fit inside a cfl lightbulb. So I think we have a clue here as to the workings of his device.
bass
If you look at the coil in the video from 2007 , where he was shows a variant of its generators in the house , the upper coil (which is like an inductor) is wound double wire that comes out of a box, and two ends connected to the load.
This, in my opinion, indicates that the coil is a distraction. And the execution of any one coil is not a Tesla transformer
a.king21
Quote from: bass on September 30, 2012, 02:11:26 PM
I think we are all agreed that it is not a Tesla transformer. That fooled the forum for quite a while. However in my opinion it still has a function - maybe part of the loop back system, maybe lowering the voltage for output, maybe even working in reverse to step up the voltage - or a combination of all of those. Although it may not be "the secret", I believe the coil is a conventional part of the system. Maybe by having output and input on the same coil - resosnance is maintained.  I still think the secret is a "doctored" transformer.
a.king21
Quote from: wattsup on September 30, 2012, 01:07:34 AM
@all
As @forest recommended I revise the 2004 device diagram with the transistor changes, I then decided to finish the complete system mapping as can been seen to not have to do it later.
Thanks @bass for clarifying the orange wire. I could not see it as entering the Tin Can but it does. Great. So I revised the last diagram and it is below.
wattsup
Looking at his patent, T1 and T2 has to be the feedback loop. Also the neutral of the feedback loop goes to ground. So three more mysteries solved - and  some, three(?) connections inside the tin can solved.
Maybe - if you agree - you could revise the diagram.
Zeitmaschine
Quote from: bass on September 30, 2012, 12:20:41 AM
3. and selected capacitor so that the UC and UL, are equal.
I think it is necessary to start with a 15 uF capacitor.
Something must be wrong with that value.
I have done a resonance test with exactly this transformer and I get resonance at 50Hz with a 1.34µF capacitor (3 × 1µF in series parallel to 1µF) on the 230V coil. Both 115V coils not connected.
As frequency generator serves a XR-2206 (VCO) set to 50Hz sine wave. The output voltage is 4.3V effective (via push-pull output stage), the oscilloscope shows 12V peak to peak without resonance (direct connected), current is 2.5mA. With resonance (capacitors in series) the voltage on the primary 230V coil goes up to 14V effective, the oscilloscope shows 38V peak to peak, current is 6.14mA.
According to the LC Resonance Frequency Calculator this means the coil of this transformer has an inductance of 7.56 Henry. Measured on the coil the resonant voltage is 3.17 times higher than without resonance. The resonant current is 2.46 times higher than without resonance.
When resonance causes a higher voltage but at the same time draws a higher current from the supply, then where is the Free Energy?
Seems I got my wires crossed, hence what to do next based on these findings? ??? :(
