0 Members and 147 Guests are viewing this topic.
verpies
Quote from: semenihin-77 on October 03, 2012, 05:42:09 AM
Simple experiment
Source of static electricity, which is located between the ends of the coil, the coil magnet. Coil is connected to the LED.
While the magnet coil - the LED light. No magnet - not light.
I don't understand.
What is a "magnet coil" ?
What is the source of static electricity?
Jack Noskills
I measured the input power in my step up trafo, no change with accuracy of 0.00 amps, it showed 0.31 amps all the time. I also had light there and no change in that either.
I based power increase on the sound of the sparks, reminded me of the sound car engine makes when nitro button is pressed, well sort of. Steady high pitch whizzle and much louder than without ground. I also poked it with amp meter and it went off scale. But it was digital so cannot trust that too much. However, it was within scale when ground was not connected and went off scale when ground was connected.
Third was a more painful observation. I adjusted the spark gap position one time since it did not fire properly, using iron tool lol. Occasionally fired but not constantly, no shock received. It seemed safe to poke it by one hand when circuit was operating. I was unable to get a decent spark so I placed the ground wire because it made spark more intense, while I was adjusting the spark with iron tool. Big shock on my left arm all the way up to my neck. Definetly it was sucking power from the gound, no doubt.
Haven't tested cascade version, could be that frequency goes up in the ground connection so second stage can suck more power. If this is not the case, then more power can be sucked using higher drive frequency than 50 Hz. This is worth testing, there is no resonant frequency so testing is easy. First try the one stage version, if it works then continue from that using cascade or without it using just plain trafo.
Jack Noskills
Quote from: verpies on October 03, 2012, 04:59:40 AM
Watch Mytbusters. One of their episode busted the myth that a lock-stepped army platoon can resonate a bridge to destruction (wind - yes, boots - no) and in another episode they tried to shake a building and a bridge with a "tapper" like Tesla did allegedly - it did not work.
I watched part of the tapper episode. They stopped the test because it worked and they got scared. The effect was on certain frequency only. Don't have the link, it was in some long document that expainled rodin, VTA, SM and the rest.
