0 Members and 493 Guests are viewing this topic.
jbignes5
Quote from: Zeitmaschine on October 14, 2012, 11:50:16 AM
Why not make a bifilar pancake coil out of aluminum (or copper) foil instead of thin (flat) wire? One layer conducting foil alternates with one layer insulation foil. Then you can have a rolled foil capacitor and a bifilar coil in one piece. Of course it is then not pancaked anymore. :D
Because the inter-wind capacity will be wrong then. I have not tried square wire or even aluminum yet. I'm assuming the round wire presents a certain spacing and orientation to the electric field in the coil. Changing that will also change the volume of oil in the coil and change the dielectric capacity.
For now the traditional round conductors and only of copper will be used. Once we figure out that is really going on here then we can start changing the materials of even the shapes of the conductors and see what changes there are.
My thoughts on the multi layered coils and design I proposed should keep all of the properties of the bifilar in order and compact a huge flat pancake into much smaller form. It should also keep the accelerating mechanic alive and well if we flip the conductors at each doubling back point. If you look at the design you will see that every wires is surrounded by the completely opposite wind or polarity. This should improve the concentrating effect and give an improved acceleration of the energy injected. It could be that we have to layer the pancake coils like Meyers did in a bobbin type setup but I want to try my version first.
27Bubba
Quote from: dllabarre on October 14, 2012, 11:48:57 AM
I would have a local friend replicate it first to verify it can be replicated and not a fluke.
This way I can create instructions that are detailed enough for someone new to this type of device to be able to replicate it.
Then I'd post the instructions, parts list and measurements I got.
It would be your responsibility to get the exact same components I used or don't complain if it doesn't work for you.
Eventually I'd sell a kit with the components I used, minus the coils.  You'd still be responsible to wind your own.  Winding coils is a PITA  :(
I had planned on informing Kapanadze first, before I released my information to the internet, but now I feel he's had plenty of opportunities to take ownership and release his secret.  He obviously isn't going to do it.  So I wouldn't inform him first.
That's my plan anyways,
DonL
Bravo!!
As I see it , this would be the RIGHT THING to do considering how it would benefit everyone..
Zeitmaschine
Quote from: a.king21 on October 14, 2012, 08:45:08 AM
Would you be full of glee  all over the forum and produce an "instructable"? Would anyone?
The I would not be the first one that has a working Free Energy device but I would be the first one who changes the course of the world by publishing a technical instruction of it so it can be easily replicated by anyone. :P
Quote from: jbignes5 on October 14, 2012, 12:04:46 PM
Let's hope there is no oil involved in the Kapanadze device (can't see dripping oil anywhere).  It would be very impractical if any self-powered device (like a vacuum cleaner or a mobile phone etc.) would work only with a tin can full of oil. :(
yfree
Quote from: Zeitmaschine on October 14, 2012, 01:48:44 PM
Working principles of TK devices are known since  February of 2012.
Construction details of TK devices were published in August of 2012.
All is in here in Chapter 3, starting on page 3-114. It is very simple.
a.king21
Quote from: yfree on October 14, 2012, 03:07:07 PM
I found it impossible to take this article seriously for two reasons:
1 Where is the working replica device?
2 The electromechanical device is smoke and mirrors because we have met the designer
of the mechanical components and they have no idea how it works. I also told TK this and insisted on the AQ2 being built
instead. He didn't contradict me, instead he sheepishly agreed.
There is however the possibility of subliminally giving the secret away - I do not dispute that.
As usual talk is cheap. Pub talk as far as I am concerned.
So as they say in Dragon's Den, "For that reason -  I'm out".
