0 Members and 76 Guests are viewing this topic.
Doug1
Troll of the month is page is really funny.As I am a robot I can not post a comment there. Even though i did have something stupid to say. lol
captainkt
@jbignes5, sorry car radiator is copper and brass, only new car rads are ally. Also this earth was not used for demo the water pipe/tap was better.
Keith
starcruiser
I was playing with my Tesla Coils and noted an effect that might have a bearing on the TK device, I will post pictures later when I get home to demonstrate what I am experiencing.
I have a 12ga stranded ground wire running up a 1" x 1/2" x 24" piece of wood which is the same height as the secondary (24") when I hit the right modulation and voltage point the wire, which is grounded, produces its own streamers from the tip of the wire which is stripped back about 3/4". The streamers do not reach the coil but are very visible and present.
My thinking is that the ground wire, like a single turn coil, is picking up the radiation, could this be the effect TK is exploiting?
for a continuation of my experiments, I will be using an additional secondary, that is close to the driving secondary, with a smaller primary inserted in the center of the secondary. This is similar to what Wings had posted. I have several smaller secondaries I have wound that I will try as well.
Regards,
Carl
a.king21
My conclusion is that wattsup is right. So what do the transistors do?
They have to be used for something. They are obviously part of the original build.
Primitive IGBTs anyone? Then where does that logic go? Tesla switch maybe?
Zeitmaschine
Quote from: a.king21 on October 24, 2012, 01:15:36 PM
A capacitor switch maybe? :D
Quote from: Сергей Ð'. on October 23, 2012, 04:52:51 PM
What American Patent Office have done and still do ?? It's very simple. Those puppets had collected and still do, all patents which they can grab and "remade or pollished the most important contents" leaving analogisms and modified and incorrect drawings.
I see! No wonder that the patent No. 514,168 makes no sense (to me). »THEY« have polished away the phrase »OVER UNITY«. :(
Then we have no choice but to modify/polish the patent one more time till it makes sense again: The two capacitors are charged with high voltage from a transformer. As soon as the voltage is high enough the spark gap fires and short-circuits these capacitors. Therefore the energy stored in these capacitors is released abruptly into the thick copper bar (or the primary of a second transformer) and thereby creates a current that behaves very oddly.
Now questions: Is it necessary to short-circuit the capacitors by means of a spark? Is it necessary to do this with (very) high frequency? Is it necessary to do this with (very) high voltage?
As it seems Tesla had no other means but to do it with a spark gap which requires high voltage which automatically results in high frequency. But since in modern times we have such things like transistors and thyristors there should be no need to do this with a spark.
Normally if one short-circuits a fully charged capacitor (with a screwdriver perhaps) then the stored energy in it is lost. But has anyone measured yet if the lost energy in the capacitor is possibly higher then the energy initially supplied in order to charge the capacitor?
Yes, I think there is one: Freie Energie "Kalter Strom" Präsentation (the German language experiment video)
Jörg Raimund Hempel is the name. He charges a huge capacitor and then he claims that he can do this with less energy in than energy out when he afterwards sort-circuits the charged capacitor. This would mean there is no other magic in his setup but charging a capacitor relatively slow and then discharging it abruptly (Bearden's ramp generator says hello). Now could please someone tell Mr. Hempel that he just reinvent the principle of the Tesla patent »MEANS FOR GENERATING ELECTRIC CURRENTS«? :)
So this would imply the principle of work of the TK device is simply to short-circuit one (or more) capacitor(s) the right way. A lot of capacitors are presented in the 100KW tent setup and they are surely not there just for fun (but to abruptly charge and discharge them in rapid sequence).
If a battery or transformer or generator is short-circuited then the amperes which can flow at maximum through the wire are limited by the internal resistance of that power source. But since the internal resistance of an ideal capacitor as power source is zero ohms the maximum current that can flow (for an brief instant) out of this capacitor is not limited but rather infinite. And when in a physical system a value goes to infinity then strange things can happen.
This much for free electric energy due to a short circuit ... ::)
