0 Members and 83 Guests are viewing this topic.
verpies
Quote from: Zeitmaschine on November 12, 2012, 11:40:21 AM
OK then: What exactly is a Breakdown Voltage of a diode?
It's the voltage at which the diode starts conducting in reverse.
If I use a diode rated at 400V and I apply a (peak) voltage of - let's say - 1000V then the diode breaks down (it conducts in both directions).
It would be more precise to write that this diode conducts forward for voltages ≥ 0.6V and it conducts in reverse for voltages ≥ 400V.
But the breakdown is most likely permanent, means the diode gets destroyed in the process.
It is not permanent. It stops as soon as the voltage falls below 400V.
The diode does not get destroyed in the process of reverse breakdown, but can get destroyed by high current or overheated junction. The latter is not a problem if the current is limited externally or the junction has the time to cool down between the reverse breakdown pulses (e.g. low duty cycle).
Except it would be a Zener diode. But the diagram shows not a Zener diode. So what's wrong with my thinking?
Every diode behaves like a Zener diode above its reverse breakdown voltage. It's just a matter of the magnitude of this voltage.
Bipolar Junction Transistor junctions behave the same way.   They break down and avalanche in nanoseconds, e.g. see this video.
Also, besides the amplitude characteristics (vertical characteristics on the scope), diodes also have complex time characteristics (horizontal characteristics).
For example diodes conduct high reverse current for a while, after the voltage across them changes polarity.
Zeitmaschine
Quote from: verpies on November 12, 2012, 05:05:46 PM
So the next question would be: What is the advantage in not using a Zener diode to have a reverse breakdown but a non-Zener diode? Or the vice versa question: What is the benefit of Zener diodes if ordinary diodes can do the same job?
Just wondering ... :)
x_name-41
here is the answer but is encoded:
password:123456
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
verpies
Quote from: Zeitmaschine on November 12, 2012, 06:40:15 PM
Lower reverse breakdown voltage.
verpies
Quote from: x_name-41 on November 12, 2012, 08:03:13 PM
password:123456
I don't feel like doing cryptoanalysis at this time of the night.
What is the type of this data (GIF Image, PNG Image, ZIP Archive, Text, etc...) ?
Is it Base64 encoded and XOR'ed with the password (at what block size) ?
