0 Members and 709 Guests are viewing this topic.
baroutologos
Thanks Omni, a lot for making this translation. It helps much.
baroutologos
I resume today my Melinchenko experiments
Various loads tried (10w and 20w bulbs), various voltages tried (21v, 39v, 52v) with virtually no difference (but higher volatge is better due to lesser amperage used for given power and less lossed to heat).
Gap at my small transformer makes a big difference. A 3mm gap diminishes fully the whatever effect. Optimal gap used was 1mm.
In order to see if there is any gain of gap usage i made:
*an ungapped version. Lamp1 made to full nominal brightness (9,5 watts) and Lamp2 with the larger inductance winding was smoldering at 2-3 watts at best 555 pulsing efficiency. Amperage was measured at 0.4 A at 39v. Calculated 15-16 watts. Efficiency of the system 75-80%
*a gapped version of 1mm. Lamp1 again was reached at nominal brightness (9.5 watts av.) and lamp 2 was far more intense. Estimated 6-7.5 watts. The 555 was pulsing at 2.29 Khz 17% pulse width.
This time consumption was rised to 0.5A at 38.7 volts - 19.5 watts . Efficiency  80-88 %.
From the above it is readily seen that the gapped version is more efficient under the specific circuit configuration. By the way, my results always were underunity. I am pondering on the fact why the gap produced better efficiency than the ungapped version.
In order to be fair at Melinchenko's  suggestion the same experiment must be conducted with a larger E-core transformer so the results to be more striking whatever they may be. Nevertheless, initial findings are a bit dissapointing.
I also could not managed at making strick calculations because the would requir the usage of smoothing caps after the diodes. Smoothing caps, electrolytic (63v 1000uf) and AC motor start (400volt 10uf) posed a noticeable losss (do not know why) to the system diminishing lamp's brightness whereas consumption was the same.
So i proceed my calculations by judjing lamp's brightness to be the same as operating by a Dc source. It is worth to note that Melinchenko described meticulusly his experiment but does NOT make any measurement at the load lamps. Only suggests to do so.
Pirate88179
Very well done!  Thanks for doing these experiments.
xenomorphlabs
2 new pics of SR´s replication have surfaced on russian forums.
In the first it is now clearly visible that there is NO WIRES coming from the coil AT ALL.
There is only 3 cables connecting the coil with the circuitry.
There is no way that any schematic that was discussed earlier correlates
with a coil of that connectivity.
It can´t be an ordinary inverter transformer (with center tapped 2 half primary)
Under the table there is a relay visible where one lead of the lamp was connected in the video.
The other thing behind that might be the mentioned 20W transformer (maybe)
darkspeed
