0 Members and 475 Guests are viewing this topic.
deggory
(http://www.freepatentsonline.com/6741153-0-large.jpg)Flat High-voltage Impulse Transformer - Patent 6741153[/font][/size][/u]
hi everybody i am also into building Tk coil , as going through google patents i have came across a patent to create high voltage from flat coil transformer like Tk use......... is this what he do ............. please check this patent .
http://www.google.com/patents/US6741153
A flat high-voltage impulse transformer is proposed, which can be used in conjunction with a high-intensity discharge (HID) lamp to provide a high-magnitude pulsed voltage to ignite the HID lamp. The proposed transformer structure is characterized by the use of an elongated magnetic core that is made of a magnetic material having a substantially square hysteresis loop and whose saturated flux density is at least two times greater than ferrite, and the primary winding is arranged at the middle section of the elongated magnetic core while the secondary winding is arranged at opposite sides of the primary winding on the elongated magnetic core. This feature allows the transformer of the invention to provide a better voltage transforming effect, and also allows the transformer of the invention to be made more flatted in profile to provide a compact size.[/font][/size]
Сергей В.
WattsUP: I am still waiting your elaboration !! :) Did you made experiments with high amperage current source pumping the ground? It will be good to present your schematic and experiments to public finally !!
yfree: Red used strong magnets not ferrites as magnetic separators!!
all: Does anybody of you will make experiments or do nothing as usually? I don't see sense to bring schematics and information which nobody has tryed experimentally!! It seems to me you are looking for FREE ENERGY nut in fact you doesn't want to find HER !!
Watch #99520
http://realstrannik.ru/forum/39-kapanadze/87845-analiz-replikaczii-ustanovki-tarielya-kapanadze.html?limit=18&start=17442
Reg. Сергей В.
yfree
Quote from: Сергей В. on December 10, 2012, 02:32:42 PM
This is not my drawing. I would not call it a "magnetic separator", but axially magnetized gain medium.
The main point is that if it works, it works as described by McFreey.
a.king21
Re commissioning a device from Kapanadze.
I have contacted his translator and will get back to you all with
his response.
I suggest you organise  a treasurer for the venture.
dllabarre
Reg. Сергей В.
I do experiments all the time.
I read through most of the pages on the Russian website you posted using google translate.
But I can't read Russian and google doesn't translate the Russian words that are in an image.
So it becomes very difficult to replicate from the images posted without the translation and without parts list and coil construction details.
But Thank you for your postings.
DonL
