0 Members and 139 Guests are viewing this topic.
baroutologos
Further questions
By seeing the newly released pictures of SR's device i have some questions. First the obvious one.
Suppose the ferrites as seen are glued together to form a solid core.
I can see only:
1 cable from each side (blue-red) and one or two in the middle. Those make barely 2 windings.
There are 3 wires + ground entering the one way (blue wire's side) and two wires + ground leaving.
What are those wires? Do the ferrites have holes and are connected to other windings above?
Secondly,
Supposedly it is the procedure mentioned by the patent and as said it was replicated by member  tehnar6 of next energy forum.
Suppose the core creates an increase of magnetic field in comparison to the one formulated by the L1-L2 coils. Why this field is collected on the designated winding L4 and not upon the initial electromagnet winding??
3rd) What the ground role here?
romerouk
I mean success in utilizing high voltage(for me it was the only way).I was pulsing capacitors charge from the rotovertor circuit  to a 240/12v transformer using IGBT.I was able to get 11.5volts/1.8amp using 18volts/750ma for the input.I will try to reproduce the circuit and I will post it to youtube. I am thinking of a better way to collect and utilize high voltage but I had no time for it...
[A author=baroutologos link=topic=7679.msg238722#msg238722 date=1272034528]
You mean the diode plug?
I have used it in the past by making a resonant LC in mechanical setup. Nothing of gain in any circumstance. What do you mean as great success? The only one that claims success with this toy is Hector Peres that made it.
[/quote]
hartiberlin
Quote from: amigo on April 22, 2010, 10:09:35 PM
*Everything* came from a Czech patent from 1996 and relates to transmutation of Fe56->Fe54.
Here's the original patent: http://spisy.upv.cz/Patents/FullDocuments/284/284333.pdf
Here's the Russian translation: http://www.001-lab.com/001lab/index.php?action=dlattach;topic=4.0;attach=4112
Here is the english translation via Google Translator:
The method of energy production by converting Fe 56 in Fe 54 nuclear magnetic resonance. Equipment for the implementation of this method
The invention relates to a method for production of electricity through the conversion of Fe56 Fe54 by nuclear magnetic resonance, when the effect of the magnetic field and electric current leads to the transmutation of the isotope Fe56 and electrons with energies obtained by transformation of the isotope (10?) Collected in the form of electricity. At the same time addressed a means for the application of this method as a generator with the nucleus 56 Fe
Current state of matter
Currently, there are many known methods of energy production. Nuclear power is traditionally obtain fission or fusion reactions of atoms and the energy of electromagnetic waves
obtain the magnetic induction induced by the flow of electrons.
We also know that energy can be obtained using the principle of nuclear magnetic resonance.
The invention F 9110472 was described a procedure in which a strong magnetic
transformed field and electric current on the iron isotope 56 Fe isotope mutation of Fe56 in
Fe54, the emitted energy. Iron core is heated to a temperature of at least
150 ° C and subjected to electric and magnetic energy. Effect of energy strength
168.21 x 10 "-13J in the iron core of the isotope Fe56, induced instability, which in turn leads to changes in iron Fe56 Fe54, with the release of 2 neutrons. They are transformed into magnetic energy and resources of the induction itself. Applications of the invention F 9110472 also describes a device for implementing this method. The device consists of metal parts made of mild steel square-shaped "U", a cylindrical rod of iron isotope Fe56,
of three coils, power supply and output flow and the required circuit. The first coil forms the magnetic field generator that allows the channel of the nuclear spins of atoms 56. The second coil acts as an activator of nuclear magnetic resonance and nuclear spin-rotation of the atom allows for 180 °. The third form of the coil of the transformer, which collects real inductive energy. It deviates from the device and then converted, if necessary, and commercial
used.
PRINCIPLE Inventions
The essence of the invention is that it is not addressed much more effective way of generating electricity using the transmutation of iron Fe56 to Fe54, a pure nuclear magnetic resonance, is the isotope of mutations, where at least part of získávaného current flows back into the iron core. The remaining current was removed from the device for further processing and use. This allows you to disable the main source of input power, as his replacement.
Power parts produced current. This is achieved by subsequent self-run production, but also increases the amount of energy, experience. The current resulting from a mutation of the isotope of iron, in accordance with the invention, therefore, divided into two parts, one of which is sent back to the iron core passes through it and will be charged at a different location, and the second part is removed from the site. The invention is based on the observation that in the isotopes Fe56 and Fe54 there is the potential energy, in contrast to the binding materials and cohesive energy. It works when the iron core, which consists of the isotope Fe56, with an initial energy measuring 168.21 x 10 "-13J, the heat kernel up to a temperature of 150 to 1500 ° C. If the nucleus has a magnetic energy of not less than 460 W and a frequency of 21 MHz, a magnetic induction of at least 0.5 T, the isotope Fe56 absorbs most of the energy, making the sales of their nuclear spins 180 °, and then released two neutrons to form the isotope Fe54 these two neutrons in its release of release of energy. This energy is both to use the invention for further mutations isotope of iron, as it distracted from facilities in the production of electricity, if necessary, converted and then used.
Once, to ensure at least the value of current required to maintain the process of mutation, it is ideally the input to turn off or disable input, and this process could take up to occur spontaneously until exhausted Fe56. After exhausting all Fe56 can replace nuclear power as a new and equally to the whole process again. The proposed method of power generation is much more efficient than current methods of isotope mutations in Fe56 Fe54, is comparable to other energy sources, such as by fission or fusion, as well as the optimum for commercial use. At the same device is intended to implement the above method of production of electricity.
Funds for implementation of the method in accordance with the invention is based on the existing site of French PV 9110472, which is a generator consisting of a conductive, preferably metallic structures and he introduced the iron nucleus Fe56 in the form of bars, at least three induction coils, the input power source current, at least one source of stress for products of this device and the necessary circuit relationship.
Iron core is deposited to form a magnetic core inductors. Spools should be at least three, at least one consists of a coil of an electromagnet, a magnetic field, at least one high frequency and generates the base plate and at least a low frequency and used to obtain the magnetic energy released iron core. Iron core, the field consisting of transmutovaného iron packed so that the system was stable, he is either vertically or horizontally, fixed in the carrier
construction, preferably in a metallic conductive structures U-shaped. This device is compared with the current addition, measures for supply circuit, obtained by transmutation, back to the pole. This scheme allows stimulation of the current transmutation of attracting at least one of the coils back to the steel core, the current obtained from the transmutation of the nucleus are sent elsewhere. This can be implemented in such a way that the output current, at least one low-frequency coil connected back to the rod, but to find a solution to flow from the rod. This significantly increases the productivity of the equipment, and about three times compared with the original equipment.
The device is convenient to enter the supply of the input stream from the source to turn off the regulator is equipped with this source of input current. Controller is connected to the input of the current equipment, but also associated with the release of flow from the device and the output current to obtain the transmutation of the rod. Current evacuation with a steel core, this current increases the current generated in the conversion zheleza56 in Fe54, so convenient via the controller, which is also connected to the input of primary current in the device and the output current, the device. The controller is configured so that when the input size in the current reaches the preset parameters, cut off the source of the input stream.
Economical if the regulator set value equal to the amount necessary power to the device. After an initial phase, the device will perform the transmutation of iron 56 in Fe54, and when the size of the production flow reaches the necessary values, we can follow the closing of sources of loss and operation of automatic devices, until the economic exhaustion of the isotope Fe56
The device may have different design options. The minimum number of turns three years. Favorable to the amount of stored energy and the flow velocity transmutation, if the device has four coil. They chose a comfortable and arranged so that the first coil of an electromagnet generating a magnetic field, at least 0.5 T. The second coil - coil of high frequency is higher than the frequency of 21 MHz, and the source of at least 467 Tues / gmol. The third and fourth coil low frequency, it ranges from 45 to 55 Hz. The third and fourth coils can be combined into one, or it may be associated with the production parameters of the required number of coils is increased.
In the case of the plant arrangements with four coils, which, in our opinion better, the current increase from the fourth and / or a third coil, but the best of them, and then led to the steel core, preferably at the other end of the rod. This is to ensure that the output current of the fourth and / or a third coil connected to the input in the field, forming the core, and it is conveniently located at the end of the rod. The current then passes through the rods to pass this flow transformation of iron 56 in Fe54 to further enrich their current obtained transmutation. After passage of the current bar, enriched stream obtained from the transmutation of lead away from the opposite, namely the end of the first rod. Thus, the results of this flow are conveniently located at the end of the first bar, and the input current from the coil or coils on the pole is at the other end of the rod. One of the ends of the rod must be provided by isolating the case for his exclusion from the stand. The coils are chosen so that the first acts as a coil of an electromagnet, creating the necessary magnetic field, the second coil is another source of energy, causing fluctuations in the basic component of the magnetic resonance, and the third, and possibly other pathogens are the coils of a sinusoidal wave and, consequently, nuclear magnetic resonance . Spread enriched stream obtained transmutation removed from the pole is in the given parameters by
transmutation of iron is about three times greater than the current entry of the rod.
Output current, obtained by transmutation of the rod advantageous terms with the division into two parts, first part connected to the input of the controller, and the second part deals with the release of the device. Stream, removed from the first end of the rod, then the current flowing through transmutation of iron-fortified then divided into two parts. Divide the better about the ratio of 1:9. The first part of the lower reaches and then switch to the regulator and integrated into the power circuit, which is replaced by the input current from the source to allow the input stream to disable the automatic power and operation of equipment, while the second part of a large current diverted to the output device for further processing in As power consumption device. This relationship has been established experimentally and calculations.
The device according to the invention is suitable for commercial production of electricity. Much better performance than the device described in Annex F 1190472 AA comparable to devices used for electricity production in other ways, such as nuclear reactions or fission. This equipment is clean and safe, and no reference to a special source of energy.
Browsing images
The invention further illustrated by drawings, where Figure 1 shows a cut in favor of the design of the generator with the controller and four coils. Figure 2 shows a diagram of the elements of the generator, Figure 3 shows a section of the generator is easier to implement without the controller and the three coils, and Figure 4 shows the diagram elements of the generator.
Examples of the invention
Example 1
Exemplary of the invention is a generator, shown in cross section in Figure 1 and schematically in Figure 2
The generator has a base of support (base) structure of U-shaped, consisting of the lower sheet and two side walls, which are made of steel and chrome. The size of this structure 1 configured to power 50 kW with a linear value is somewhat up or down. The body structure 1 in the holes and fitted with an iron rod holders 2, consisting of the isotope Fe56. In the left side wall has a hole under the diameter of the rod 2, and he saved the first 3_ end of the rod 2, so that he has created a strong bond with excellent thermal and electrical conductivity.
The right parties has increased, and there is opening deposit of the second end of the 4 bars 2, which is also equipped with a Teflon housing 5, that he was on the structure of an isolated. An iron rod 2 consists of four main magnetic coils 6, 7, 8 and 9 Participate and selected as the first coil of the electromagnet 6 is the creation of the magnetic field of 0.5 Tesla. The second coil 7 is high, has very little appears about 20, and is powered by a voltage amplifier 10 which supplies the voltage to 500 V transistor structures, plate 5, and I have made it amplioscilátor Class A. The third and fourth Roll 8 Roll 9 is a low frequency of 50 Hz . Interconnected in a row. The device also contains a source of H input current terminal block / 2 for input and output current and from the device, a current meter 13, controller 14 automatic operations and the required electrical circuit.
The participation of elements of the generator is shown in Figure 2, the input current from the source of H is connected through 13 meters on the first Reel 6 and third reel 8, whose output is connected, and thus, Paid, fourth, 9 reel between the third and fourth coil 8 coil 9 is ongoing, part of the enriched mainly formed to convert iron Fe56 in Fe 54 and, consequently, Paid, plug the other end of the four iron rod 2 Pride for the first 6 coil must be reasonable, whereas the current from the third coil 8 is connected to the other end of the 4 pole 2, is recognized around the rod 2 and the first end 3_ enriched energy derived from changes in Fe56 Fe54, is held. It consists of one part is connected to the controller 14 and is fed by the second part of this is due to exit from the device. The controller 14 also is connected to terminal 12 input and output current and from the device. It is configured so that as soon as they reach the main part, which comes into it, the value of the input current,
After depletion of the isotope Fe56 remove iron rod 2 and replace it with new, the whole process again. When these settings are needed to process the alarm about 15 minutes, after which the actual operation of automatic devices for the presence of the isotope Fe56 has about 2400 hours. This procedure has an energy 32040x10 "I9J, which show a higher efficiency compared with existing equipment for production of electricity.
Example 2
Other exemplary implementation of the invention is a generator, shown in cross section in Figure 3 and schematically in Figure 4 The generator has a base support structure 1 and U-shaped, consisting of the lower sheet, and two side walls, which are made of steel and chrome. The size of this structure 1 configured to power 50 kW with a linear value is somewhat up or down. The body structure 1 through the holes and fitted with an iron rod holders 2, consisting of iron isotope Fe56 left side wall has a hole in which to store the end of the first part of the 3-2, Teflon bearings 5, so that he was against building a stronger bond is formed with excellent thermal and electrical insulation. The right side of the rod has a diameter of hole 2, which contains the other end of the 4-piece 2, so that the connection to the structure of the perfectly conducting. An iron rod 2 consists of three magnetic coils Core 6, 7 and 8. The first coil of the electromagnet 6 is the creation of a magnetic field of 0.5 Tesla. The second coil 7 is high, has very little appears about 20, and is powered by a voltage amplifier 10 which supplies the voltage to 500 volts triode plate structures 1 and creates its amplioscilátor Class AA third coil 8 is a low frequency of 50 Hz. The device also includes a source 11 input current terminal 12 for input and output current up to and on the opportunities and the necessary electrical circuits.
The participation of elements of the generator shown in Figure 4 the input current from the source channels connected to the third coil 8 and the first coils 6 Pride for the first 6 coil must be reasonable, whereas the current from the third coil 8 is connected and, therefore, goes to the other end of the 4 poles 2, is recognized around the rod 2 and 3 by the end of the first enriched energy derived from changes in Fe56 Fe54, is directed at the outlet of the device. After depletion of the isotope 56 Fe is removed iron rod 2 and replace it with new, the whole process again.
When these settings are functioning equipment in the presence of the isotope Fe56 lasts about 2400 hours. This procedure has an energy 32040x10 "I9J, which show higher efficiency than the existing facilities to produce electricity.
1. The method of energy production by conversion of Fe56 Fe54 by nuclear magnetic
resonance, when the iron core, consisting of the isotope Fe56, has a magnetic field
and an electric current causes the conversion of Fe56 Fe54, which is produced by electric
current from the facility, and then converted, if necessary, and proper use, characterized in that at least part of this transmutation were fed back into the iron core.
2. The method according to claim 1, characterized in that part of the current transmutation is fed into the device, generating a magnetic field, and then, when this part of the current should reach at least the current values are entered into the device from the source, disconnect or power off, then the process could be self-transmutation until all isotope Fe56, and the remainder is produced by the current from the object.
3. Equipment for carrying out the method according to claim 1, which represents a generator consisting of an iron nucleus Fe56 in the form of bars, at least three induction coils, the input power source current, at least one source of stress for products of this device and the necessary scheme of relationships that form the core generates the magnetic pole core chokes and stored in the structure of the U-shaped form, characterized by the scheme to be set to pass at least part of this transmutation got back to the poles / 2 /
4. The device according to claim 3, differing from the input current is connected regulator / 14 / in speakers / 11 / the input stream and the regulator / 14 / as well as the current output from the device and the output current to obtain the transmutation of the rod / 2 /
5. The device according to claim 4, differing from the regulator / 14 / is set equal to the cost of the necessary power to the device.
6 devices on items 3 to 5, characterized to be equipped with four coils / 6, 7, 8, 9 /, the first coil / 6 / an electromagnet generating a magnetic field at a distance of at least 0.5 Tesla,
The second coil / 7 /, at least with the frequency of 21 MHz amplifiers / 10 / at least 467 Tues / gmol and the third coil / 8 / and the fourth coil / 9 / is the frequency from 45 to 55 Hz, in which the output current from the third coil / 8 / and the fourth coil / 9 / is connected to the input end of the second / 4 / web / 2 / and the output shaft / 2 / for the current obtained by transmutation, located at the opposite end of the first / 3 /, and one of the ends / 3,4 / Rod / 2 / is provided with insulating frame / 5 / for the isolation of the design / 1 /.
7. The device according to claim 6, characterized in that the output current obtained from the end of the first transmutation / 3 / web / 2 / comes with a division into two parts, first part connected to the controller input / 4 / and the second part deals with the release of from the device.
hartiberlin
Here are 2 pics from this patent and russian DOC file.
hartiberlin
@baroutologos
interesting effects with bringing back the high voltage line of the secondary
back before the sparkgap in your Diagram A part Y)
It probably just raises the voltage so the sparkgap can better build an arc and thus
more RF will hit the incandescent wire and light it up some more...
The question is, why it only work with this one bulb ?
Do the other bulbs have a different resistance and other wire forms inside ?
Regards, Stefan.
