0 Members and 226 Guests are viewing this topic.
elementSix
TK's spinning disc is just like Faradays Dynamo.  A large spinning copper or brass type disc is spun by a small motor and with magnets at a 90 degree angle from each other.  The magnets are put in the 4 directions, ie N,S,E,W.  The disc makes high current low voltage.  You can even glue the magnets to the disc and get the same result.  Pretty simple.  I'm sure you can change the high amp/low voltage into a useful product.. Dr. Linndamin made one of these and made a good informative paper on all the different orientations that he tried.
Zeitmaschine
OK, since my equipment is not ready yet, some more theoretical stuff.
According to this very enlightening patent (Сергей В., you're sure this is not Stepanov patent?): METHOD OF PARAMETRIC RESONANCE EXCITATION SWITCH ELECTRICAL OSCILLATIONS AND A DEVICE FOR ITS IMPLEMENTATION
It is all about switching the capacitance (or inductance) in a LC circuit in order to get more energy out than it goes in. The interesting part is that this is done almost the same way as it is done in a Power Factor Correction Device. The main difference in the latter case is that the capacitors are statically switched, whereas in the first case the capacitors are switched dynamically (in dependency of the waveform) by means of thyristors or triacs. The method is called parametric resonance. The resonance frequency in such a circuit changes constantly.
Wikipedia: »Remarkably, if the parameters vary at roughly twice the natural frequency of the oscillator (defined below), the oscillator phase-locks to the parametric variation and absorbs energy at a rate proportional to the energy it already has. Without a compensating energy-loss mechanism provided by beta, the oscillation amplitude grows exponentially. (This phenomenon is called parametric excitation, parametric resonance or parametric pumping.)«
That means if someone plays around with a (thyristor) switchable Power Factor Correction Device (maybe three-phase) then there is a great likelihood that he will discover a parametric resonance effect by chance.
Oddly, on over 1000 page here I can't find the term »parametric resonance« very often, and if I can find it then it is either not explained in depth or its existence is even denied at all.
So we have the Stepanov device with transformers, capacitors and thyristors. We have the Kapanadze devices with transformers, a bank of capacitors (specially designed for power factor correction) and two heat sinks which each can hold a triac (instead of two thyristors), and we have a patent drawing of a device that shows four thyristors and which is described as
»switching method for excitation of parametric resonance and device for its realization by excitation of parametric resonance of electric oscillations by switching method, reactive electric power is generated
And then we have the Steho AG which also claims to have an electric power amplifier based on a resonant transformer (p. 6, in German) and which actually is the Stepanov device.
And then we have the Steven Mark Toroidal Power Unit which looks suspiciously like coils, capacitors and some switching elements. Since the shape of the coil obviously does not matter, it can be anything fancy with a futuristic look.
Now tell me someone that this all is just a (faked) coincidence. >:(
Quote from: hartiberlin on February 17, 2012, 02:54:59 PM
It is said, that the 2 disc are of steel and brass or maybe each disc is
a double layer of steel and brass and that these discs are connected via a brass wire, that is isolated from the steel shaft.
The toroidal transformer, that is put around  the shaft seems to be
the main motive power source and it is said in the "broken" Russian-German translation
that it uses just 8 Watts of power.
This movie is from a new release from a Russian movie from youtube user Realstrannik
http://www.youtube.com/watch?v=vZC5CwCTv4I
Since the above mentioned patent claims a method for generating electric power by changing the capacitance dynamically in a LC circuit and the TK motor consists obviously of a coil and a capacitor which forms a LC circuit (the two discs are the capacitor plates with the coil between) then what could happen when the capacitance of this capacitor changes somehow dynamically due to its rotation? Could it perhaps generate energy?
Just asking ...
P.S.: Since today the Mayan-Calendar ends (but the world seems to be still there yet), this would be a very good day for someone to tell me that this theory finally works. :)
verpies
Quote from: Zeitmaschine on December 21, 2012, 06:00:18 AM
Hasn't Wattsup already shown that TK faked his 2004 demo with external power delivery ?
"Two capacitor plates, made of brass and steel"
What video is this snapshot from?
Where do you see capacitor plates made out of steel ?   I see only 2 yellowish brass disks.
Zeitmaschine
Quote from: verpies on December 21, 2012, 06:37:58 AM
All what was shown was a blurry video but no conclusive fake.
Snapshot video link is in the hartiberlin quote. The narrator talks about »Messing und Stahl« (brass and steel) in German language.
