0 Members and 495 Guests are viewing this topic.
grizli
Quote from: gyulasun on April 26, 2010, 11:35:31 AM
EDIT: If you short circuit a coil of a few number of turns, it would not kill the total flux of primary because the coupling between them is small and here you involve air core coils, no closed flux path. Definitely introduces some loss but it is negligible, so that is why it is used in shaded pole motors.
Would not kill but will alter resonance frequency of reciever it will not mach the resonance of transmitter and energy  from transmitter will not be used
gyulasun
Ok it detunes the receiver coil but can it be retuned at the receiver coil again?
grizli
Quote from: gyulasun on April 26, 2010, 12:28:29 PM
Bart should try to retune it by top capacity variation ..
baroutologos
There too many things that by theorizing someone cannot perceive that a plain experiment in this area can beutifully convey.
@Guyla
Regarding shorting:
Its not that the few turns and loose coupling are not interacting with resonator,. Its just that the shorted coil, poses no load and extracts no energy, whereas if it bears a load (even though lesser current flows through it) , extracts energy and poses serious "drag" to main resonator.
Secondly, the Kacher is a self-adjustable resonance device. No matter what, it will always run in resonance mode even though at less oscillating power if a load is applied to the vicinity of it.
Thirdly, i tried to "adjust" the receivers to better resonance by approaching my hand towards the topload of it. That way by bringing my hand to a definite distance, lamp's brightness could be boosted whereas the other receiver experiences diminishing results and vice versa.
I do not know about phasing or current shifting. If i knew nothing about those things i would say that shorted does not extract power so all OK, whereas underload extracts power from the system so not all OK.
Lastly Griz, i would not bet my head that a shorted secondary diminishes primary's magnetic field at that frequencies rates. (obviously it does not)
grizli
Quote from: baroutologos on April 26, 2010, 01:02:29 PM
All in all i wonder how would it behave if there would be more than two recievers
Did you ground (real earth) all recievers and transmitter ?
would it be possible you make youtube video in which you will record how you move those two recievers you have in relation to themself and relation to tranmistter ?
Or can you answer this :
When one reciever is tuned and is near transmitter , and when other reciever approaches from the opposite side  whats is 1st reciever brightness lessens  accordingly
what when 2nd reciever comes close to 1st reciever ?
