0 Members and 130 Guests are viewing this topic.
Hoppy
Quote from: jbignes5 on January 31, 2013, 08:37:21 AM
So now lets look at Tesla or TK's magnification. If you had a weak force you could channel and control in your device, how could you make that usefull? Lets look at an amplifier. We take a weak control signal and control a massive power with that weak control. That in a sense is a magnifier. Exactly the same as the analogy of the sun through a magnifying glass. We make usefull a Vast weak force and concentrate it to do more work then could be possible with the weak force. Plain and simple.
In both cases the massive weak force area are condensed or magnified upon the area we choose to get the amount of force we want for useful work.
What do you imagine TK was magnifying  ;)
jbignes5
 I suspect that it was the movement of the capacitors capacity. LEts say the capacitor has a charge that is defined by the mass of the capacitor. The capacitor has an innier plate and exterior plate. The inner plate is shielded from all external events by the external plate. This internal plate is the anchor. In the case of Tesla one wire we can see this internal plate as the environment or base. The external plate is the copper plate or acess to the external plates charge. This is an inverse of the closed capacitor but none the less works as stated.
If we look at Tesla's improvement of capacitors we can see him using one real plate and another virtual plate(liquid). The real plate determins the capacity since the virtuall plate can not be easily changed. Second picture in patent.
Reference: http://www.teslauniverse.com/nikola-tesla-patents-567,818-electrical-condenser
Tesla figured out that any plate of any shape will vary it's capacity via how far from earth the plate is. Just like in the experiments with open variable plates. The further you move them apart the higher the voltage goes between the plates. This is because of variable capacitance based on distance between two plates. But i suspect this changed the strength of the current. The further they become the high the voltage but the weaker the current is.
It is an open capacitor and hence has the ability to focus all the space of one plate (Earth) upon the real plate (copper). This allows one to suck in and magnify all the free charges like heat into the system for conversion to electrical energy. The oscillator is merely a way to pump and select the frequency of the target free charges. The coil/iron is the way to create a one way valve and the load (spining copper disk) is a converter to work and again heat to be released back into the environment.
Again I should show the visual reference to this to make it easier to understand:
My understanding of this process is by far not complete and this is what I got so far. I do not know everything despite how I may make it appear. Tk's methods are very close to this I am betting and should be looked at in this light.
In the picture below there is but one plate to the capacitor (round globe) The other plate is the earth. Now the Earth has another plate as well and that is the interior plate. Between the earths plates is a massive well of heat and is what I suspect is the anchor(constant). The free radiant energy is in the air all around us and is what it tapped to get work from. The radiant energy is in the form of heat which is radiated from the earths outter plate from the internal capacity. Hence the word to describe this energy is "Radiant energy".
x_name41
Quote from: jbignes5 on January 31, 2013, 10:23:07 AM
Quote from: autor x_name41
Quote from: autor ПАПЮС post=108800Доброе время суток!
Вот что я нашел на просторах интернета, на мой взгляд заслуживающее внимания:
Генератор Капанадзе 2012
и доброе утро, ну да это один из секретов или принцип работу установки так сказать (имею виду "Второй закон термодинамики и без топливный генератор Тесла") а еще будет и другой секрет, вариант где установка работает и без заземления (Mustafa007 работал над этом) но она более сложна а еще кроме того и в обе будет резонанс
source: http://realstrannik.ru/forum/39-kapanadze/108060-generatory-kapanadze-obshhaya-tema.html?limit=18&start=36#108803
and this: http://realstrannik.ru/forum/39-kapanadze/105968-odnoprovodnayarezonansnaya-sistema-peredachi-elektroenergii-kak-klyuch-k-genu-kapy.html?limit=18&start=18#108328
elementSix
When Tesla says he gets HORSEPOWER from this, That would have to be Current, Right?  I mean without current you don't have much use with a large Electric Motor.  You need Current for the Horsepower to move the motor.  Those big motors back then probably used a lot of current... ??
jbignes5
Lets wait before jumping the gun ok that guys.
Here is a model of all earth layers Picture 1.
Now Tesla made extensive tests to figure out the capacitance of the earth, Why?
Well if one knew the capacitance of the earth given the dielectric strength of the air one could figure out what one needed to make a plate that would be harmonic of that inner capacitance. Ie be resonant with the inner capacitance. Then one could design a perfect system to be resonant and draw out the radiant energy of the heat that his device was bathed in.
It isn't all voltage and even if it was one could just step it down and get all the current one needed through that process.
We know now the value of the external sphere in the earth system in voltage is 300,000 volts at it's peak. and can be concluded that is the value of one plate of this 3 plate capacitor. Tesla also noted the gradient of voltage from earths outter shell to the earths atmopheric shell. One plate is the earth itself, the other plate is our artificial plate (coppper plate) and the last plate is the outter plate of the whole system. Hmm this is starting to look like a vacuum tube.. Weird....
