0 Members and 40 Guests are viewing this topic.
Farmhand
Quote from: forest on February 01, 2013, 07:21:14 AM
Farmhand
Please don't mess people in heads ! Power is all we need, but SUSTAINED power , not a power burst but continuos power magnification and this is what Tesla did and if you carefully read that (and other ) patents you will surely agree with me. ONLY REAL POWER can generate various effects he described in his lectures., if that was only HV or high frequency he would never use the term : magnification.
You touched the truth saying he had HUGE reactive power in his circuit - yes, indeed. And he knew how to convert it into usable effects and that's all what we need....
Here I want to mark something which may sound silly for you : I believe in RCL resonant circuit power is always real until disturbed. Like a soap bubble - nice look but you do not touch it
I'm trying to help, I can just as easily not try to help. But I don't do it just for you, I do it so an ever increasing number of people do not pick up the same misconceptions. When we see a spark or arc that is real power yes, but the accumulation of energy which enabled the high potentials to produce the effect is oscillating power. The real output power is what goes out of the system, the oscillating power stays in the system, oscillating. The real input power is the power that replaces losses and the actual output so as to maintain the high power oscillations, so that the output effects can be had. Depending on how the circuit is arranged some of the oscillating power could become reactive power and go back to the source. There are many different situations which could occur with different circuits. The addition of a de-q-ing diode can stop energy returning to the source of a DC powered system and so eliminate reactive power even though the oscillating power is still there. The way I see it the oscillating power in an L/C tank is not necessarily reactive power, it's active power or activity and it's all in the system until it leaks off as radiation (losses) or is taken as a load, then it is real output power.
Cheers
elementSix
http://www.youtube.com/watch?v=UsS0BeVeIwM    Karl Palsness AEPC 2009
These 10 videos are mainly on Tesla Hairpin circuit, but they have some good remakes of Tesla HF transformer that is specially made and when powered up it draws large amounts of Ambient Energy to it.  He says that in the dark you can see the wire coil he holds up in the Air, light up a bit and you can see the energy going toward the HF Coil. Watch it and lets try to make this special HF coil..
garrypm
Hi
I wonder if TK was simply looking for a way to slow down power meters ?
Just got my bill - over $800 for the quarter!
Search net for tricks to "slow" power meters and came across this -
"The 'meter running backwards when welding' thing is a real phenomenon but it's only a factor with 3 phase installations and a welder across just 2 phases (huge assymetrical loads and rotten power factors).  The distributors have an answer for that one unfortunately, they fit meters with detents that prevent the disk running in reverse."
Will now dig a bit deeper. Interesting how you need 3 phase eh.
Garry
zcsaba77
Zeitmaschine
Quote from: garrypm on February 04, 2013, 01:37:00 AM
A backward running meter due to a connected welder (if this story is true) indicates that the welder produces electric energy and wants to feed it back into the grid (like a solar panel does), therefore the meter runs backwards. Now when the distributor prevents this by fitting the meter with a detent then actually he acts illegally because he steals the energy generated by the welder without paying for it. :D 8)
So, how to replicate the function of a welder without actually welding something? How to »rot« the power factors with just coils, capacitors and thyristors? Ideas?
