0 Members and 51 Guests are viewing this topic.
baroutologos
Hi everyone
I just post on youtube one of my first experiment with ferrite core transformer. Please do not judge me wrong if there is something you all been testing for the long time. I just would be happy if this could help to solve puzzle around this humanity worth device. If there is any interest I can send the schematic end explain more in details, otherwise thanks to all and Удачи (good luck)!
d.
http://www.youtube.com/watch?v=DNKG2Slh-_U
Thanks Dole,
Its a breath of fresh air to see someone experimenting with bizzare setups.
I want to have the same experience of yours.
Can you make a diagram, components, and mode of operation of your device?
Thanks,
dole
Hallo again,
Here is fast end dirty drawn circuit, simply we charge condensers in series and discharge them in parallel through the small spark gap, rather say arc, resulting in current rush in very high vibration. It is look like only magnetic. I cannot measure anything before I transform it again through capacitive coupling or like in this last video inductive coupling. I will post some pictures of components. (2 x 202K 40kV in parallel on each side, ignition transformer 10kV, 220V inverter)
Yes I have very much to tell, but its feels sometime that it can hurt someone including me so I usually don’t.
This conversion is totally could, lamp will barely become warm in full brightens and it is totally harmless, no burns, I tested discharge of several cm between hands without any injury, but it is very sensitive to get it proper. I believe that with proper adjustment we can achieve any effect we could imagine, tuning to resonance.
I’m sorry for short disturbance, there is so much we do not know and see.
d.
amigo
Frankly, I think everyone should have taken a totally different stance on SR193's alleged replication. His alleged replication should've been treated as unverified until proven different with full disclosure on his part.
But instead, a wild goose chase had begun with resources mobilized by many people in the FE community around the World to try to figure out from a lousy video and a few stills what SR193 had done and how. That spun dozens of theories and branched out to far distances, unrelated and probably pointless, in hope to reverse engineer his circuit.
The onus should be on those who make claims to provide full disclosure, and until that time that sufficient number of replications has been secured around the World, be treated as unverified.
Refusal to provide full disclosure should be treated as an attempt at deception and the claimant should be considered a con-artist until full disclosure is provided.
God knows, every day there's a new video up on YouTube with a claim of one sort or another, and half the people here are guilty for peddling them around the Web, hyping it up and posting links to videos and starting pointless and mindless conversations riddled with speculation and conjecture. Case in point this thread.
Kapanadze and SR193 are both con-artists, until proven otherwise. No amount of photos and grainy videos of black (or green boxes with arcs) can vindicate them when they are the only ones "successful" at their claim and refuse a full disclosure, for whatever reason. No excuses.
We only have ourselves to blame though, as it is our fault that we have given them attention they did not deserve, or earn, yet.
xenomorphlabs
@amigo: So the point of your post is?
Let people speculate as long as they want. It´s their freedom of speech and their decision what they do with their time.
Your words reflect a lot of "Everybody should act as I want them to"-attitude. Please contemplate about yourself a little.
@dole:
Your circuit is indeed interesting. I have experimented with capacitor parallel discharges as well and there is some research into this that looks promising.
Could you please confirm the values of your capacitors?
You wrote :
Quote2 x 202K 40kV
Is that 2,000pF capacitance?
They are rated at 40 KV voltage each single one?
Do you remember how many windings (виÑ,коÑ,,) you put on the coil former and at what wire gauge?
What is the coil former? It looks like ferrite rings in your drawing.
The coil is a series bifilar (basically one wire bent in the middle) ?
baroutologos
Hello Dole,
Thanks for the information. But I am afraid More info is needed as Xeno, has said.
I would suggest at first at refraining from being over mystified since i have plenty of experience that high frequency currents even powerful ones have radically dissimilar behaviour than standard electricity.
By the way, your coil over ferrite core (those pieces on core are ferrite right?) is a standard one that at ending the wire goes two times inside the ferrite cavity? (wound parallel to core)
