Zeitmaschine
Quote from: cheappower2012 on February 09, 2013, 04:23:15 PM
In the past there have been many, mix frequencies ,output equals overunity,in each
case ,it was a measurement error.This applies to the Westly device
unless a device is looped you have nothing but hot air.
Then what is preventing the loop? It is the kind of energy output that almost in every experiment is high frequency or/and high voltage. Therefore I would actually prefer to make experiments which gives an output of 50Hz sine wave. Hence why not make a Joule Thief that uses an iron core transformer at 50Hz instead of a ferrite toroid?
Apropos »looped«: There is one more thing to keep in mind, and this is ... err ... Ed Leedskalnin's Perpetual Motion Holder which defy (or defeat?) the laws of physics.
An iron core with two coils stores (loops) the energy indefinitely. But these are obviously the same parts a 50Hz transformer is made of. Hence can a 50Hz transformer also store energy indefinitely? Interesting question.
If the secret
of TK's device were found it would cause a world wide economic system collapse.
I'm looking forward to it.
This projection is illogical,this leads to some silly theories,this same thing happened with
the tpu thread.With the recent crap of verpies=wasabi my feeling is jjbignes5 =verpies=wasabi=Hoppy
possibly a few more,trust no one.
Yes, trust no one ...
... unless he gives you free energy.
Quote from: verpies on February 09, 2013, 03:12:22 PM
He is describing one of the proven methods to avoid mutual inductance.  Your joining of the two toroids by the shorted center winding, is completely different.  It makes the orthogonality of the cores irrelevant.
No center winding. One toroid is an ordinary Joule Thief with a bifilar winding, the other toroid has one single coil wound on it (but maybe also bifilar) and both are arranged perpendicular to each other (or in a way that gives the best results).
verpies
Quote from: Grumage on February 09, 2013, 06:17:20 PM
What I am trying to say is that there is something curios about the relationship of Ferrite and HF, you can hear it hissing. I wonder whether there is an interaction with the binding material?
Sound is caused by magnetostriction or core slapping due to Ampere forces.
Graham Gunderson has a patent for an energy generator using magnetoacoustic phenomenon.
Anyway, your 1:1 transformer is symmetrical - do you still get loaded voltage increase if you connect it in reverse? sec<->pri
elementSix
The circuit-controller, it may be stated, is any device which will permit of a periodic charging of the condenser F by the energy of the supply-circuit and its discharging into a circuit of low self-induction supplying directly or indirectly the translating devices. Inasmuch as the source of supply is generally of low potential, it is undesirable to charge the condenser directly therefrom, as a condenser of large capacity will in such cases be required. I therefore employ a motor of high self-induction, or in place of or in addition to such motor a choking or self-induction coil E, to store up the energy of the supply-current directed into it and to deliver it in the form of a high-potential discharge when its circuit is interrupted and connected to the terminals of the condenser.
  In order to secure the greatest efficiency in a system of this kind, it is essential, as I have before stated, that the circuits, which, mainly as a matter of convenience, I have designated as the "charging" and the "discharge" circuits, should be approximately in resonance or electromagnetic synchronism.
    Moreover, in order to obtain the greatest output from a given apparatus of this kind, it is desirable to maintain as high a frequency as possible.
Tesla designed a great adjustable Self-Induction Coil, in which Don Smith used in his demonstration during the 1996 Tesla Convention..   The adjustable self-induction coil in the circuit with the condenser, by the adjustment of which the period of vibration of such circuit may be changed.
Hoppy
Quote from: cheappower2012 on February 09, 2013, 09:58:25 PM
Hoppy
I do have an agenda but it is not to
fool anybody ,misdirect anyone or get attention.
OK, then what is your honest opinion about TK's devices being genuine insofar as not requiring an external power supply to power loads?
forest
Quote from: SchubertReijiMaigo on February 09, 2013, 06:34:45 PM
It was that...
Then I exposed both theories:
The conventional when you have Under-Unity.
The Hector Perez OU theory.
If he have equipment he can now play.
You have not answered my question....
Your statement is good....analyse that trying to ask  the correct question about it , then further analyse will bring you the whole set of possible solutions like a tree.... One branch may give you (probably) the way to answer....
